OBDEleven Formentor - See below for working ones
Zahc
10
Just a quick thanks to everyone who has contribuited to this thread. I have had fun playing with OBDEleven and have changed everything I wanted to.
The rear light bar on with DRLs is my favourite, along with the adjusting the lane assist to remembering the last setting. Still playing with the fake engine sound level, but suspect I'll be setting it to 0%.......
Great stuff!
Reactions: tracktoy and Tell
Mares
16
Serbia
Hi guys, new to this forum, can't wait for my new formentor 2023. 2.0 245hp that will be delivered around new year. I started to investigate about modifications and I am curious if coding affect car warranty void?
If so, in that case 12 months Pro plan of OBD11 Nextgen would be useless for if I want to keep car warranty, right?
Tell
It's a bit of a hot chestnut. You don't tell the dealer you have done it. The Pro plan is the best solution rather than the micro payment apps. QA aspects of them can lead to the car randomly programmed whilst coding with the Pro license you can reverse what you have done. Thus it's all under your control. Micropayment apps are black box solutions for people that want an easy life. They are put into the Obdeleven line up as an answer to other one click apps but can suffer from the same problem.
On my Ateca I keep off engine performance modifications. That would excite the dealer and it's warranty should something occur.
Lankan
17
9
I just got the OBDEleven (and Formentor), but I have yet to try it.
There are some great contributions on here from other owners, which is good to see. I have a list of 'must-dos' but I am concerned about the impact in making certain changes have on insurance, especially if the changes affect the functioning (or not as the case may be) of supposed safety systems/functions.
Any opinions, or actual experiences?
cairus
1,145
406
Just as a hint, it is no longer anonymous. If push comes to shove, they will prove that you "manipulated" the control unit. With SFD anyway
Tell
Prior to SFD was more tricky. Still the PCP people that don't technically own the car, the finance house does in association with VAG, can only have a life of polishing their pride and joy (detailing) since everything else is breaking their agreement 🤣. Some humour there. What you mean it's not my car... err.. no. So those guys can get umpy about coding since they can't although one suspects 99% do or would like to.
the_winner
39
10
33
Athens,Greece
Hello,
I own a Formentor VZ 245 E-Hybrid, new to this forum , i am familiar with VCDS as i work always with VAG Cars , i have read all 26 pages here in forum , thanks to all members for the infos .
I have alreay enable :
1) Easy entry (drivers seat go back when you want to enter the car or when you want to leave the car etc)
2) Fuel tank liters
3)Soundaktor at lower level
But i can't found anywhere some of the below
1)when you unlock if the seat is at different memory position to go back to the key-matched position
2)i have seen at a lot of hybrid owners that at the battery status bar they have enable the % how can i activate this?
Reactions: Zahc
Mares
16
Serbia
Need help with OBD11 PRO long coding, I am trying some modifications according list of German author, but can not understand what to do when it says byte 3 -> activate byte 6 (for easy entry). I can not see anything relating to this undr STG36?
This also refers to other modifications, when it says byte X -> byte Y...what does it mean?
Btw, as I am playing music from USB flash drive, is it possible to save volume level I set so next time I start the car I do not have to turn up the volume again?
Jaco2k
AWD FTW
Mar 11, 2018
1,048
643
Tampere, Finland
www.youtube.com
That refers to long coding
Tell
In the Pro you got the 0-1 slider that takes you into the string editor if that helps. You move across etc. One has text on it the other is the editor. I have taken in the past VCDS stuff and converted it into Obdeleven... hex stuff. That was on the Ateca Cupra thread on why the mib2 standard on Ateca Cupras didn't have the Cupra image on them. I then made my Standard Ateca into a Cupra with the Cupra splash screen... on my high unit. Seem to recall I used hex tables if someone gives you VCDS stuff it's possible to do the conversion. Bottom line on the mib2 standard was it didn't have the Ateca Cupra car images in it, the high did... in case you hit this on a Google.
Haven't got the Formentor but pass on the rest. On sound I guess you got a menu to setting to turn auto volume off. That compensates for road noise. Audiophile thing to do in anycase. Then you probably got a other menu setting also to do what you want.
Tell
The 0-1 slider
And taking VCDS output into the long string Obdeleven input
That's an example of taking one and using it in the other.
Source:
