Ok, I thought it was simply software related. There are others who claimed to have done it, but I've seen no proof of their success.the slip ring must fit and the wiring is also missing
It's a bit of a hot chestnut. You don't tell the dealer you have done it. The Pro plan is the best solution rather than the micro payment apps. QA aspects of them can lead to the car randomly programmed whilst coding with the Pro license you can reverse what you have done. Thus it's all under your control. Micropayment apps are black box solutions for people that want an easy life. They are put into the Obdeleven line up as an answer to other one click apps but can suffer from the same problem.Hi guys, new to this forum, can't wait for my new formentor 2023. 2.0 245hp that will be delivered around new year. I started to investigate about modifications and I am curious if coding affect car warranty void?
If so, in that case 12 months Pro plan of OBD11 Nextgen would be useless for if I want to keep car warranty, right?
i must check and post back ...Which Data have your STG 17?
Also curious on this one..3)show the gears at the D mode D1,D2,D3 etc
That refers to long codingNeed help with OBD11 PRO long coding, I am trying some modifications according list of German author, but can not understand what to do when it says byte 3 -> activate byte 6 (for easy entry). I can not see anything relating to this undr STG36?
This also refers to other modifications, when it says byte X -> byte Y...what does it mean?
Btw, as I am playing music from USB flash drive, is it possible to save volume level I set so next time I start the car I do not have to turn up the volume again?
Sent from my SM-G965F using Tapatalk
