Tell
Walone
1,632
461
Near Heathrow
Thinking about it, one of those links is suppose to be the dealer one and the other, the consumer one. Take the one which is the fastest. Probably on different servers. Both links get found and get posted up.
I did wait for the download to complete, haven't installed it yet. :)
Reactions: Tell
leonlad
1,165
54
london
Will pass on the last. That's open up and short those pins.
You shouldn't need the mib2 hight Mr Bonk toolbox just 1447AIO you'll probably have to fiddle with the sound. There is something about the Seat Sound system and Vag files East Yorkshire Retrofit has mentioned that before.
I'd test it first. Jot down the TMC group, if it's 15 then it doesn't have connected services, 3xxx from memory it does. Better if it's 15. Note the Canton business. Then do the 1447AIO. If successful change 15, 14. Workout the sound, the picture images and what still needs to be configured.
e
well i updated to the latest skoda one first mu1433 which went ok apart from having to turn off MOST to get it to run, tried the seat one but did not like it error: variant conflict
2015 unit and never had an update not even the maps :ROFLMAO:
probably need to edit the metainfo file
shame mibwiki is down :no:
leonlad
1,165
54
london
He's AWOL. Perhaps you'll have to have a picture of a Skoda on it :oops:. You should have life long FeC on a Skoda. Car image library ?. Possible useful link.
once the seat firmware goes on all the seat imagery will be there i think , the toolbox should enable everything should it not as i will have to patch CP anyway ?
Nov 20, 2024
Hi, all. Last month i buy Ateca FR 2018. I mannaged to update the software to the latest version MHI2_ER_SEG11_P4709 but ti cannot/dont know how to update maps.I have maps installed on my device, i dont have sd card. I downloaded the latest version of the maps P390_N60S5MIBH3_EU. The sistem says that the update of the maps are found but it dont update the maps. Can somebody please help me how to do it? Maybe my FEC dont allowing me, or am i downloading the wrong version of the maps? Thanks for your help in advance.
Walone
1,632
461
Near Heathrow
The FEC for the maps is the one starting 073000, not sure what your one means, @Tell will know i'm sure!
I'm wondering what benefit I would have updating my software from P4708 to P4709?
Reactions: crff
Tell
Yes I've just covered it here in another post he did. So we are all good.
Reactions: Walone and crff
Nov 20, 2024
Well thanks for this guide, I know have 2023 maps :)(y)
I updated from 0425 to 0480 with no issues, it came up with some note about a code. I just left it and it rebooted fine.
I downloaded the P106_N60S3MIBS2_EU_NT (8V0060866S).7z from https://mibsolution.one/#/1. Extracted it to my HDD. I then removed a few files in the markets/eu/map/MapRegions folder. Ukraine and turkey stuff if I remember correctly, this made the files fit on the original card. Modified the DbInfo.txt by copying the original one from my map car and changing the last 2 lines to
ApplicationSoftwareVersionNumber="0106"
SystemName=" ECE 2023 "
from the new map file.
I then copied the contents of the original card to my HDD.
I then formatted the original card to fat32, and copied over the new files, put the card in the car and waited for what seemed like hours. It now works.
hello... I accidentally deleted my original Dblnfo.txt. can you send me your Dblnfo.txt from your original SD card?
Tell
no. I formatted my original SD card and forgot to save the backup. I had a V5 europe map. i have installed 480 firmware but the map is not working. i think there is something wrong with the DBInfo.txt file
I see you problem. @Daz3d was v4. You are one above... newbie error of deleting the data without taking a copy. Hopefully someone will come along.
