Yes on 390 / 393 I'd missed MartiniBs posting from a week ago being preoccupied with Windows 24 H2I saw that but its mainly for car image - those are the same - only climatronic screen is black
390 eu and 393 row? I found on https://mibsolution.one/#/1/15/MHIG - MHI2(Q)
So I could use that; wasnt sure looking on size, thanks
Also sadly from sport gauges only G meter works(not important but turbo pressure would be cool ;D)
It does ring a bell that I looked at those parameters once. I don't use Android Auto so I'm not the best person on the connect side. It's where the port is conditioned for data. @Walone might know a VCDS owner. Mere obdeleven pro person here...I visited today my friend with ori vcds; changed usb mode from function + iphone to only function and android auto started working.
But I couldn't figure out IDE02502 check software ver.. (1555 dtc fix)
I had 47 06; calculator said new should be 8E D4 but no matter how many times I trieid it - Error; request out of range... so I left it like that.
I'm not sure but he's doing long coding yourself and said that he's updating vcds 1-2 times year. I searched for informations regarding it and it may be caused by UDS protocol? The program is too new?registered as a developer in vcds?
Pass on the VCDS, it's another world . Those are macro scripts that they run. IDE whatever do you pay for that. Just a script that you can do in the Obdeleven Pro but you just type it in. Expect those IDE things are like Obdeleven micro payment apps but VCDS costs you much more ?.... unless you got friends in with dodgy cables. Alliexpress.registered as a developer in vcds?
Long coding is Obdeleven Pro equivalent.I'm not sure but he's doing long coding yourself and said that he's updating vcds 1-2 times year. I searched for informations regarding it and it may be caused by UDS protocol? The program is too new? View attachment 45030
Would that be the Audi version of 1447. Probably. Audi drivers turn up on the Briskoda site looking for the map update after they have their version of 1447AIO. Basically doing the same tricks on the Audi mib2 high firmware. Clever developers getting the metacheck sums right. They must have an automated process they can't do it by hand. The SLA1 signature is avoided by the POI exploit else you'd have it on a bench or with some box attached in situ how mine was done. 4g aerial and box of tricks with the unit pulled forward on a motorway service station. Retrofitter solution.I bought obd11 for my father's car but missed lifetime pro version by couple of months.. it expired and paying 50€ for year just to change version info is not good for me as i'm on budget rn
That's why I went to friend who has workshop and original vcds to make those.
If that's only hidden dtc in 5F I will probably leave it for now..
But as I made android auto on mine car right now I have questions from father if I could activate aa for his car too but other one is audi; MHS2_ER_AU_P0448 so i dont know
I'm not sure.. i checked on mib helper and as most recent version it shows MHS2_ER_AU_P2035 personally coudn't find any aio and despite MHS2(mib2high?) it has sd card with maps. On this car he has added rear camera so maybe then they updated somethingWould that be the Audi version of 1447. Probably. Audi drivers turn up on the Briskoda site looking for the map update after they have their version of 1447AIO. Basically doing the same tricks on the Audi mib2 high firmware. Clever developers getting the metacheck sums right. They must have an automated process they can't do it by hand. The SLA1 signature is avoided by the POI exploit else you'd have it on a bench or with some box attached in situ how mine was done. 4g aerial and box of tricks with the unit pulled forward on a motorway service station. Retrofitter solution.
Footnote. Thinking about it, that was the usb port thing that I mentioned earlier up, it wasn't that they needed changing in these older cars for data but coded. Does beg the question of why I looked at this once, given mine came setup for AA. Perhaps I thought the retrofitter had messed it up when I got the firmware changed for mapcare so I checked it.
I see Mr Fixit has a video on free maps for Audi.... saying that he can get you into terrible trouble if you fumble things. He says in thar video how to do it from the map file. What I'm saying is if it uses the map cards to run off them it isn't a high unit. 23...ee is the life time map fec.I'm not sure.. i checked on mib helper and as most recent version it shows MHS2_ER_AU_P2035 personally coudn't find any aio and despite MHS2(mib2high?) it has sd card with maps. On this car he has added rear camera so maybe then they updated something
