Is that a Wiggins connector? And 83mm throttle body? Wonder what response is going to be like at small opening angles, shouldn't be a problem
Aaaaanyway, this build is still damn epic!
Very Nice Work VTSlow progress, too much work load and too little free time at the moment.
Welding practice for 3.5" tight aluminium bends
Changes of plans with throttlebody mounting, building new adapter and adding short bend between adapters. it increase a little volume of plenum which might be good thing but otherhand throttle plate isn't directly on the manifold which might be negative thing. Let's see how it goes, at least it should make boost pipes easier to build and with less tight bends.
Very Nice Work VT
Also great to see that it's not just my work bench that looks that way in minutes
This would explain how from the post 'Tomorrow' done yesterday that is actually today and will get sent at 7:10pm later on.
So by my calculations VT86 made himself several extra hours and a time machine! And would explain many things, probably?
What's next?
Hover-conversion?
Keep up the good work VT86
306GTi6 I remember those,Next lets try to get Smurf back on the road, and maybe, just maybe something extra spices. Need to reserve time to prep 306Gti6 also for the summers track days.
In fact so that if you look outside VT86's workshop you'll see a queue of brass monkeys waiting for their turn on his spot welder
I believe that bus left a long time agoWhat the actual f...? This is officially the most mental build series so far
