You are all awesome! I have tweaked my 2023
Formentor e-HYBRID with Lane Assist Warnings and Default, Speed Limit Assistant, and Undertaking ... after backups
I have hit the "
FUNCTION NOT AVAILABLE" error when trying to complete the following 3 other changes - yes I have enabled SFD and I had the bonnet undone (but not up) with driver's door open ...
REAR LIGHTS ON WITH DRL
Daytime running lights / Parking Light already “Active” from dealer
When I attempted:
Immediately then do this
- Select Central Electric 09
- Select “Adaptation”
- Select “Daytime running lights”
- Select “Tagfahrlicht-Dauerfahtlicht aktiviert zusaetzlich standlicht” ( Scandinavian DRL )
- Select “Active”
RESULT : Front and Rear DRL working ( No fogs lights on ) - Result was
ACTIVATE DRL CONTROL IN INFOTAINMENT SYSTEM
- Select “Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich”
- Select “active”
Result was
ACTIVATE CRUISE CONTROL OPTION IN MENU
- Select Control unit 13
- Select “Long coding”
- Select “Cruise control mode”
- Select “Activated”
Result was
Any ideas team?!?!?!?! I only have a few days of OBD Eleven PRO membership left to sort this ...
