MIB-Wiki
70
55
FAT32 doing this on MAC often Leads to issues.
You can use both SD card slots.
USB should work as well.
Tell
If a Mac use CleanMyDrive utility, run on the SD card after unzipping. That's takes out the Mac rubbish... but saying that I'm not sure whether AIO would get effected by the rubbish, but it wouldn't be healthy. Keka for unzipping on a Mac and CleanMyDrive on the card once unzipped is the Vag recommended way, 32gb Fat32 card, 4096 cluster size. Think it's exFat if 64gb SD card, USB NTFS. Easier to stick with 32gb class 10 fat32 cards and do the Mac stuff if a Mac.
Reactions: MIB-Wiki
May 30, 2022
9
Hello,
Is there a new mib2 update, I'm on version 346 and h24 hardware.
I have since the update in 346 a bug with fm stations see my video. Do you have a solution ?
alias76
30
obd11 mi indica un nuovo aggiornamento h41 mib2 std zr eu 498
Tell
It is possible that those release serial numbers can be forged and then Obdeleven informs you that there is a release higher than what you have which causes excitement. Probably good for business of those people that sell software. It came up with a release above the 1447 high release. Now a technique has been demonstrated to manufacture releases which are not signed caution is required. Pass on whether it really exists.
May 30, 2022
9
MST2_EU_SK_ZR_P0366T_0366
Is a Skoda file, SK is Skoda. SE is Seat so you look within train down the list but only the SE Seat ones. So 3XX in the title as well as SE and MST2_EU_SE etc
Thanks for your help, I just saw my mistake.
I found
MST2_EU_SE_ZR_P0369T
how to update?
are there any manipulations to do such as going from 25x to 3xx?
Tell
I found
how to update?
You cant unless you have the skill level, that's the conversation here:
2xx is the 2 train, you can't jump to 3xx 3 train etc. The updates are only really designed to be done within train for the standard unit. Serious coding is required if you jump trains. When I called up Nameless in that conversation. There is a pdf you can read that covers it which Nameless translated to English. The across train mib2 standard updates are in the domain of retrofitters with programming skills.
nameless
48
24
I dont think it s supporter by this hardware... it tried on a car and it brick the unit... i had to do the special procedure to put a good version again...
