Things I have discovered about the car.
Dec 31, 2021
I tried the voice control when I first got the car, but didn't find it very accurate, and the satnav address search by voice was very slow. But perhaps I should give it another go if it seems to have improved.
As an aside, does anyone knw how to reset the Trip mileage? I can reset the Long-Range stats on the Driving Data screen, but can't fine the reset for the Trip counter, it just stays the same as the odometer (as viewed on the Classic view). Thanks.
jcbmally
Dec 26, 2013
1,279
553
Cybertron
Go into vehicle settings, then select interior then scroll to the trip recorder and reset.
Tell
On updates....Only infotainment system gets an over the air update if in the sequence of updates, trains as they call them in mib2, probably the same name in mib3. That's why some people are waiting for updates (to be released over the air) or have to go to the dealers since its not over the air, a new train.
The other software in the control units are not updated over the air. @East Yorkshire Retrofits will say if I'm wrong wrong I'm sure.
Hizzards
102
74
There’s two stages of refresh in the CUPRAConnect app; one that refreshes from the server, and one that I assume refreshes from the Car.
I didn’t notice immediately, and I seem to remember reading some people having problems with the app updating from the car, and they might not have noticed this as I don’t think it’s obvious.
Reactions: Fencer60
CupraPoopra
55
45
May have already been mentioned, but if you press the touch temperature bar with 2 fingers at the same time, i.e. press the red and blue, then it switches on the heated seats.
Subsequent presses then lower the heating setting i.e 3, 2 ,1 and off.
tetrad
33
20
Last night, when leaving my VZ3 in sport mode with the background lights previously set to drive mode, when locking the car a red ‘pulse’ of light sweeps from right to left across the dashboard light track two times. Reminded me of KITT from night rider !
anyone else noticed anything similar ?
Big A
244
156
Mine always does this when locking the car. Just thought it was a standard feature.
Reactions: MrBiggles87
butterycrumpet
Dividing by zero
Apr 28, 2021
104
70
Cheshire, UK
Not sure if a feature or a bug... but if it's dark and I unlock using KESSY the front interior lights don't come on (but the back ones do)
If I unlock using the key fob button they all come on.
Probably a bug tbh
Big A
244
156
Probably a bug tbh
Sure its a bug. Mine is hit and miss with the front interior lights coming on whether I use the remote or keyless.
  • Haha
Reactions: butterycrumpet
Mad Spoons
Spoons
Jun 27, 2005
266
60
Yorkshire
Wasn’t really sure where to ask this and didn’t want to start a new thread. I haven’t figured out how to do full screen map on the virtual cockpit. Is it possible? I did “read” the manual but couldn’t find it.
Ollie
42
19
Hold down the VIEW button on steering wheel, then cycle through to the view where map is displayed in the middle :) it will remove the info left and right.
Reactions: Mad Spoons
FormentorZ
7
UK
Haven't received my car yet and wondered could you or someone post some pictures of what the virtual cockpit looks like when you do this please?
Gbbeesls
85
75
Here you go. Hope it helps. (y)
Reactions: FormentorZ
Oct 8, 2021
77
56
It’s a great feature, but shame it can’t give it a quick blast of air after to clear water that distorts the lens.
That would be good mate. It would also be good if you can set the widescreen view as ‘default’ when reversing, I always use this view.
