Rich.T
1,609
932
I reused mine - it's just a spring in a tube and fairly easy to clean.
All the hoses fitted fine for me.
Cheers m8.
Just ordered the pipe.
Are the other valves long lasting (the one with the cable ties on). Was going to try n get a new one but wont if i dont need to.
Re the cable ties, not sure what they're on there for. The valve that they're attached to isnt damaged externally at all.
Rich.T
1,609
932
Its working when i suck n blow on it. But when it shuts off it isnt totally air tight but definitely functioning.
Nam-uk
1,256
408
lancashire.
Just had my Lufi X1 delivered. I've had a little play with it and even for me it's way to setup. Got to go and sorted for work, wahoo Nightshift. So will have to wait until Wednesday to have a proper fiddle with it.
Sent from my Redmi Note 6 Pro using Tapatalk
looks good , I've got Dashcommand on phone and a wifi OBD module works well if you put the exact details of car in, not used it for ages though, app and module cost me around 16 quid , but don't leave the module in as it can drain battery,
Battoussai
510
163
Portugal
I would like to have one of these:
Rich.T
1,609
932
Got most of the parts needed now to refit the pcv setup. Just waiting the dealers to ring for the final bits n pieces.
Also RE the puncture... now running on 3 Michelin pilot 4 sports and a nexen!🤨
Sparkie
Angling Adict.
Sep 25, 2009
2,541
779
Middlesex
Wrestled away from the wife - drove to work - smells all poofy inside
The scent of a woman!
Love it.
If your lady keeps using the car that’s a good thing.
Soon she will be used to all its power and will be wanting more.
Upgrade time!!!!!
Badger5 Custom Map + TIP,
Reactions: Gokiwi64 and Rich.T
Sparkie
Angling Adict.
Sep 25, 2009
2,541
779
Middlesex
Mine is in for a shock replacement and quick once over before track days on Monday.
Can’t wait. Had 3 cancelled in last 12 months
Reactions: Rich.T
Rich.T
1,609
932
Anyone able to help this chap out?
Gokiwi64
Geriatric Member
Apr 26, 2014
1,379
722
Hockley, Essex
Love it.
Upgrade time!!!!!
Just need a zorst and can go stage 2 ...........................225 straight to eleventy million bhp's :cool:
Reactions: Sparkie
Fishbowlhead
Mk3 CupraST 280
Nov 20, 2020
148
80
UK
Full service done yesterday along with a new aluminium dogbone mount. Has definitely increased vibration at low rmp and ignition on, but has cured the wheel hop on full boot. See how i get on with it long term, im sure ill get used to it.
Reactions: Rich.T
Rich.T
1,609
932
My name (loosly). But ive wanted one for ages so thought id go for it.
Ive been showing my other half a few ive found over time and she's always been a little meh about them. This time she sead go for it, so i did.
Was just under £300 all in but its pretty smart.
Reactions: g60stu
welshy46
37
44
Maanchestorr
I need banning from ebay for abusing my bank balance, also for upgrading one part only then needing to fix something else I broke in the process. Went and fitted a Cupra R fuel pump earlier only to break the clip on the power plug for the pump. Then when I tried to start the car, nothing. Put my old pump back in, aand nothing. Turns out for erm reasons the fuel pump fuse blew. Now I have no fog lights till I buy another 15 amp fuse. And I still need to refit the Cupr R fuel pump.
Reactions: Rich.T
Rich.T
1,609
932
Sounds like a case of, if it aint broke......
Been there many a time.
