Not a 100% but cosmetically I think I'm there now so it would just be engine upgrades etc.What’s next on the list for it?
There's a guy working on one!
Did all this to mine earlier in the year. Massive difference.Soundproofed all four doors, under rear seat and boot floor. Seems quieter and music is definately better. Just need to work out how take the trim off to get to rear arches now.
Cool. Thanks very much.Did all this to mine earlier in the year. Massive difference.
To get to the rear arches you need to remove the trim next to the where the seatbelt bolts into the body, the one with the clip to hold the belt, remove the bolt for the seatbelt(M8 or M10 Spline, can't remember), then remove the 2 screws in the C pillar trim(remove light on drivers side).
It should then pop off using a trim removal tool. I started in the bit around the small side window and worked my way back.
Hi. Really interested in doing this. Do you have the part numbers and what wiring was needed to do it please?Retrofitted the centre console rear USBs.
Nice gains there. What map did you get.
Hey, I got individual tuning in Poland, by Kivi Racing Factory.Nice gains there. What map did you get.
Took it for a service...
Rear Door 2So today I started the job of wrapping the horrible scratchy door pockets with something a bit softer and nicer feeling. There is a kit you can buy from Turkey, but i didn't like the felt material they use and wanted to go for something else. I settled on this stuff - https://www.amazon.co.uk/gp/product/B07DPSGXQC/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
It is a really nice sift feel material and seems to cut and stick well too.
I am lucky enough to have a new interior i am fitting so i have the door cards off. I also found removing the door handle made access much easier. Its a few torx screws and a couple of clips so not difficult.
I have added a couple of images of the door i have done so far. I am learning as i go so hopefully by the time i get to the front doors i will have perfected it!
View attachment 24327 View attachment 24328
