Cheeky haldex service @ 15000 miles.
Safe to say it needed it, the filter was quite clogged.
Unfortunately I broke the pump connector trying to get it off. Although trying to find a replacement proved difficult as the vw part number isn’t stamped on it. Managed to find it eventually so just in case it’s 1J0 973 722.
Parts required
Fill bolt (N90281802)
Drain bolt (N91082701)
Seal Kit (0CQ598305)
Haldex Oil (G060175A2) 850ml I used about 650ml
Pump connector (1J0973722) only if you choose to remove the pump.
Pump housing bolts torque to 9.5nm
Drain bolt 30nm
Fill bolt 15nm
All in all took around 2hours to complete.
