I get creaky dash when i put the hot air blower on to defrost the windscreen. Very annoying but i can live with it lol
Whenever I'm messing around with plastic trims & rebuilding dashboards, I douse all the joints & clips with spray on furniture polish.When it creaks, if I push up on where the two torx screws go in on the left side of the lower dash, it doesn't creak anymore. I can't screw them in any tighter so I'm hoping a rubber washer will sort it.
I know it's not a Rolls or anything, but rattles and knocks really do my head in...
One of these days I'm just going to get a load of expanding foam, pump it through every gap or hole, and be done with it.
The S badge should unclipped from the grille but can be tight if never removed before.Can anyone spot my mistake??
View attachment 24041 Is it easier to take off the bit with the SEAT logo or remove the bumper again??
I think I’ll do bumper off. Probably a safer bet. Can’t believe I’d just tightened the 8mm nuts on each side.The S badge should unclipped from the grille but can be tight if never removed before.
Yeah. Once you have removed the bumper a few times it’s a breeze.Could off been worse bumper off is best bet and easiest way to go
I chose bumper off. I've seen how rare and expensive those S badges are and didn't want to risk messing with 17 year old brittle plasticThe s badge comes off as a unit. You just pull forward firmly
. Clips are strong. You won’t break them.
Easy. Takes seconds. Bumper off is a faff.
Badger5 Custom Map + TIP,
never use them myself , my issue with them is most of time they use a very acid wheel cleaner as it ruins the wheels one reason i had my sd fr wheels redone and the last 2 clio16v i had the same was happening to them wheels but never redid them, even seen people with cars lacquer raising due to same thing.Finally got my car to a hand car wash today.
I could do it myself but logistically difficult (and a little lazy) lol.
Looks nice but will need to be done almost every week as the yard at work is megga dusty and its heart breaking to see how bad the cars get up there.
