Rich.T
1,609
932
Lots of these things I've been wondering about - boost pipes, silicone this and that - whether it'll help the engine breathe a bit better and maybe iron out some of the hesitation and what definitely feels like a lack in power from when it was new(er). First thing to do is the cheaper stuff, so sorting the turbo vanes and cleaning the inlet manifold is the priority, then we'll see if that has any noticeable effect on power delivery and go from there. For what I use it for, I'm more than happy with the stock car, but if I can keep it healthy and running efficiently, I don't see why it can't last as long again as it has already.
If you clean the manifold and turbo at the same time then take the car out, itll blow your socks off 😁.
The difference will be like night and day.
Dont forget to work the actuator.
Reactions: iammooks
iammooks
1,814
1,220
If you clean the manifold and turbo at the same time then take the car out, itll blow your socks off .
Fantastic. I just thought I'd got used to the power - who'd have thought that fifteen years without a really good clean might mean the engine's not putting out as much power as it used to?
Pretty excited now about doing it - I'll get the undertray off to do the dogbone mount and taking the manifold off will give me more light on the turbo to see what I'm doing.
iammooks
1,814
1,220
Mate... when I collected that bumper n stuff you didn’t look that old!
Don't start. My girlfriend is ten years older than me and she looks younger than I do.
Reactions: Manic172
Connor H
1,037
511
Essex
Got a nasty af grinding sound while reversing into my space earlier. Dark so no time to look but has me worried lol.
iammooks
1,814
1,220
At this time of year it tends to be something innocent. A couple of years ago I got some grit between my rear brake caliper and the disc. Made a horrible noise and scored the disc, but took the wheel off and unbolted the carrier and it sorted itself out.
Reactions: Connor H
Rich.T
1,609
932
**** shield behind the brake disc rubbing on the disc or bottom balljoint metal **** shield rubbing on the disc.
Connor H
1,037
511
Essex
Its enough friction to make reversing harder, im sure its not the brake shields as ive manually pried them away from the disc a couple of times on the roadside haha
gonna have to jack it up tomoz and check it out
Connor H
1,037
511
Essex
It was the alloy rubbing in reverse lol
