Rich.T
1,609
932
Just didn't notice 🙈.
Always gone to the Mk1 Forum or parts for sale.
Also i now fear that reading through readers rides will give me more adeas on things to do on my car.
Gonna cost!
Reactions: Yellow fr
Thai-wronghorse
Self proclaimed Cupra R addict & butcher!
Dec 3, 2015
2,245
1,101
Kent
Just didn't notice .
Gonna cost!
Here's another mk1 readers ride worth checking out.
bruceR
2,565
660
Monifieth, Dundee
Oh and another
Sl1ced
797
404
I remember once thai put a picture up of my car.....
Sl1ced
797
404
Here it is. Jokes on him my car is blue. His is the grey one
iammooks
1,796
1,191
Oh and another
I'm going to have to pick your brains about refurbishing my wheel centre caps.
I'm trying to decide whether to get rid of them altogether and try and find something that will fit the centre, or do what you did...
bruceR
2,565
660
Monifieth, Dundee
Hi mate, when I got my wheels powder coated - Black Chrome - was told that he couldn’t do the plastic centre covers the same due to heat and blending colours. So I peeled off the SEAT emblem and got them sprayed Gloss Black, then bought some stick on FR emblems.
Reactions: iammooks
Yellow fr
Sep 6, 2018
1,547
1,062
Sandbeds West Yorkshire
Check this one out
Reactions: iammooks and Rich.T
iammooks
1,796
1,191
I've been thinking of either doing something like that or getting centre caps that'll fit the FR wheels and either putting bolt covers on or just shelling out for new bolts.
The trouble with respraying the existing covers is that I don't have much luck spraying plastic parts that are flexible - the paint always seems to flake or split. How have yours lasted?
iammooks
1,796
1,191
Check this one out
I'd have loved to have had your parts car - I love that colour. Probably for the best I didn't see the thread until today.
bruceR
2,565
660
Monifieth, Dundee
The centres have lasted great
Reactions: iammooks
MoToJoJo
832
670
Northants
Bought a couple of parts to test on the spare engine, doing prep work in the garage, moving interior parts (double DIN setup, armrest, most of my interior) indoors and getting ready to install the Milltek stainless steel system.
Course now I'm thinking "What can I sell?"
I'll admit I'm putting off the work a little due to the cold... it's too cold to actually turn on the garage heater 😂
Reactions: Rich.T
iammooks
1,796
1,191
Errr apparently these were done two years ago still the original parts
Quite an easy job to be honest...
I've just dug out my 7mm allen key to do this when my snot won't freeze.
How did you do it? I'm planning on putting the car on axle stands, wheels off, compressing the spring, undoing the top bolts, taking the bush and bearing out from underneath, replacing them and then tightening it all up again. I've got a 21mm socket for the top mount I can slide the 7mm through and get an adjustable wrench on the socket to undo it.
Reactions: Sl1ced
Sl1ced
797
404
So... wheel off. Axle stand on. Jacked under the hub then undid the bolt at the front of the arb. With the Jack still under there move up top and undo it all. I used a long hex on a ratchet while holding a spark socket still with a spanner.
Once both are undone move down below and slowly let the Jack down, at this point I clamped the spring to get enough space to get the old one out and new one in. Balanced it as best I could then let the spring go. (I wanted to be fiddling about with a compressed spring for as little time as possible) then used the Jack to push it all back up. Aimed the top bolt through the new bush and bearing (can be fiddly)
Got the two nuts back on and tight then lowered the hub enough to re connect the arb. Double checked it all. Wheel on.
I’ve kinda made my own way using bits of three guides on YouTube. I’m not a fan of having springs compressed long I don’t trust it ha.
Half hour a side
Reactions: Rich.T
