iammooks
1,811
1,218
Manic172
Dec 4, 2018
1,443
1,571
Hemel hempstead
www.seatcupra.net
Nothing yet... just about to go to the workshop to have a play. Did have some.e one coming to look at the saxo race car to buy it but sadly due to the travel restrictions he has had to pull out.. but then leaves me a day to play with the leon ..... updates later
Reactions: iammooks
iammooks
1,811
1,218
Did you ever get the V5 sorted?
Reactions: Manic172
Manic172
Dec 4, 2018
1,443
1,571
Hemel hempstead
www.seatcupra.net
Bit of shiney for you lot at christmas
iammooks
1,811
1,218
Top stuff about the registration.
Starting to feel a bit depressed, given my car is fighting me at every step. Picked up an 18mm socket from Halfords, but have to wait for the 18mm spanner as it's looking like a two day wait for one from Screwfix. Tried to loosen the rear beam bolts with an adjustable, but it's hard to get a good grip on everything down there.
Might get a breaker bar. I'm not going to let it beat me.
Reactions: Manic172
Sl1ced
797
404
Where abouts are you? Tried b&q ?
Reactions: iammooks
iammooks
1,811
1,218
Thanks, everyone - it's been a tough week, with a four-day wait for a Covid test result (negative) and some family trouble, so I think when little things go wrong, or they're not as straightforward as you imagine they'll be, it probably has more of an effect than it would if those things weren't going on.
It doesn't help that the 'how to' guides for this are just like "undo the bolts and remove them".
I'm going to jack up the car higher so I can have a bit more room to work, and will get a breaker bar from Halfords so I can get a bit more leverage on the bolt. Once I get one side done, the other side will be a bit less stressful, and I can always put off the front bushes until later, as they're not in such a bad state. Saves some money on wheel alignment anyway...
Sl1ced
797
404
I use the pump bar from my trolley Jack as a breaker bar ratchet handle is a perfect fit!
Yellow fr
Sep 6, 2018
1,547
1,062
Sandbeds West Yorkshire
Lol love it that’s good thinking I said the same thing to a young lad at the body shop next door to me as he was struggling to undo some wheel nuts on a bmw he even had a big breaker bar on and still struggling so told to get the jack handle on as well them wheel nuts came undone with out any trouble
Reactions: iammooks
iammooks
1,811
1,218
There are loads of jobs where you can either buy the "right" tool or just bodge it with a length of pipe. I quite like the length of pipe approach - at least you can beat the crap out of the car if it doesn't work.
I'm just going to see if the jack handle will fit on my t-handle...
