Ah ****. that makes two of us
I will just leave this here .......
Interesting, by the looks of things they simply cable tie to the lower arms.Spotted these... look a good upgrade for the breaks on the leon.. any air flow must help. Can't see why they can't be made to fit a mk1
Genuine Audi S3 RS3 8V GOLF GTI R LEON CUPRA Front Brake Cooling Ducts 8V0407811 | eBay
Find many great new & used options and get the best deals for Genuine Audi S3 RS3 8V GOLF GTI R LEON CUPRA Front Brake Cooling Ducts 8V0407811 at the best online prices at eBay! Free delivery for many products!www.ebay.co.uk
Looking at the size of the nut on the bonnet lift ball joint it's an m8 or 13mm size nut....
I could be wrong it looks bigger than the 3 bolts holding the strut brace as it looks smaller so guessing it s m6 or 10mm spanner size. I would say that m6 is too small and I would go up a size and use m8 bolts with the biggest washers you can get on the under side or even cut them to a more oval shape to help spread the loading
If I get a chance I will cut or draw some thing in a bit and post a pic
Ive got plenty of ideas for solutions, but sourcing those ******* little ball end bolts is so hard. I have one here buts just over 10mm and too big to fit in the lifter strut. if i can get hold of one of those then its problem solved lol
think im gonna have to bring down to you asap mate and pick your brains
Try fitting your bonnet strut to one on your boot lit.. as they are normally m8 thread then you can put them at a scrap yard easy enough then
???I will just leave this here ....... View attachment 20374
