Dec 5, 2020
Hi guys,
I’ve got a 1.4 LEON FR DSG. I have a resonator delete booked in on Saturday? Any advice? Will the exhaust fart? Will I fail MOT? Etc.
Manic172
Dec 4, 2018
1,349
1,399
Hemel hempstead
www.seatcupra.net
Wish i found this thread before i started hacking away at it :LOL::rolleyes:
Looking at the size of the nut on the bonnet lift ball joint it's an m8 or 13mm size nut....
I could be wrong it looks bigger than the 3 bolts holding the strut brace as it looks smaller so guessing it s m6 or 10mm spanner size. I would say that m6 is too small and I would go up a size and use m8 bolts with the biggest washers you can get on the under side or even cut them to a more oval shape to help spread the loading
If I get a chance I will cut or draw some thing in a bit and post a pic
Reactions: Connor H and Sl1ced
Manic172
Dec 4, 2018
1,349
1,399
Hemel hempstead
www.seatcupra.net
I will just leave this here .......
Reactions: iammooks
Manic172
Dec 4, 2018
1,349
1,399
Hemel hempstead
www.seatcupra.net
Fozzy84
252
137
A quick clean, new LED side light bulbs then tucked up until MOT Time after Xmas
Reactions: Manic172
Thai-wronghorse
Self proclaimed Cupra R addict & butcher!
Dec 3, 2015
2,231
1,078
Kent
Spotted these... look a good upgrade for the breaks on the leon.. any air flow must help. Can't see why they can't be made to fit a mk1
Interesting, by the looks of things they simply cable tie to the lower arms.
Gokiwi64
Geriatric Member
Apr 26, 2014
1,379
722
Hockley, Essex
And we is broken again - no idea what's exactly wrong but brake lights on solid (assume brake light switch) - another 3-5 days delivery.
Also thrown up
0031,0445,0037 and 0102
All I want for xmas is a working car but LCR has turned into the Grinch !!
Reactions: Sl1ced
Sl1ced
797
404
Went for a poot to the petrol station. Now my dv when I come off of full chat is fluttering. Half throttle it’s only a tiny bit, boost gauge is normal if not holding better boost than with the oem dv, should I be concerned?
Gokiwi64
Geriatric Member
Apr 26, 2014
1,379
722
Hockley, Essex
Where can I get a decent repair manual and a proper electrical wiring including fuses diagram ? - Looking online and they are all crap or not for the LCR when you start looking into them ?-(
Connor H
1,023
503
Essex
Ive got plenty of ideas for solutions, but sourcing those ******* little ball end bolts is so hard. I have one here buts just over 10mm and too big to fit in the lifter strut. if i can get hold of one of those then its problem solved lol
think im gonna have to bring down to you asap mate and pick your brains
bruceR
2,558
647
Monifieth, Dundee
Didn’t the mk1 TT have these fitted, am sure I saw this somewhere that someone installed them to their mk1 Leon
Manic172
Dec 4, 2018
1,349
1,399
Hemel hempstead
www.seatcupra.net
Try fitting your bonnet strut to one on your boot lit.. as they are normally m8 thread then you can put them at a scrap yard easy enough then
