What did you and your MK2 do today?
ZiggyEP3
406
72
UK
Ace! Put some thread lock on the bolt that holds it to the engine. I bought a pack of 20 I've lost that many over the years. LOL.
Thanks I do have some in the cupboard so will get that on. I'm not sure if I need the APR stage 1 map again put in once fitted or will it be ok just to fit ?
Legojon
I only wanted a remap
5,311
2,741
I had Revo Stage 1 at the time and I didn't need the map adjusting.
ZiggyEP3
406
72
UK
Got the Revo induction fitted and what a pain in the :censored: to get the original downpipe clamp off and back on the new downpipe. That aside :dance: what a difference in sound :bounce:.Not been for a drive yet to get food.
Doesn't get mentioned but I had to Dremel a bit of the grill or the heatshield bracket wouldn't fit.
Reactions: Legojon
Leeoncupra
764
191
Halesowen
Anyone got any ideas to my p1093 fault?
So far ive changed
Hpfp (second hand)
Cam follower
Pcv
And fuel filter (6.6bar)
Running low on ideas now , only fault code it comes up with, car seems to run fine but something keepa triggering it
mk2 leon cupra and a q3 sline stronic 177tdi quattro
Brimfull
1,385
418
Wrexham
Plasti dipped the chrome badge and grill.
First time I have used the genuine us plasti dip. Must say it worked a treat and was far better than the uk product I used a few years ago.
Hopefully will do the seat boot emblem tomorrow.
Reactions: Wondering
ZiggyEP3
406
72
UK
Pulled into a garage as the exhaust looked droopy one side and it was the right hand bar bolted to the backbox had snapped. New one going on tomorrow.
Reactions: HansNL
Project1P
139
17
Portsmouth
Don't think I could of done this in a day! But rather in 3 :p
Replaced:
Timing belt
Auxiliary belt
Water pump
Coolant
Timing belt idlers
Tensioner
New install:
Powerflex RH and LH engine mount inserts
Powerflex lower engine mount bush (small)
Powerflex lower engine mount insert
I'll post a review of the engine mount inserts on my Readers Rides if you'd like to know more about them - https://www.seatcupra.net/forums/threads/chriss-mk2-cupra-r.448113/page-2#post-4922167
Reactions: PaulusB
380bhpdaily
1,257
573
I fitted a whiteline adjustable rear anti roll bar and rear strut brace to mine now worth every penny. I have got a front strut brace in the way too and am gonna order the matching whiteline front anti roll bar too when it’s in stock.
Reactions: Yellow fr
