Manic172
Dec 4, 2018
1,386
1,465
Hemel hempstead
www.seatcupra.net
What did you decide on the rear suspension in the end?
At the moment it's going to have custom built gaz holds on the rear with damping and rebound adjustability as well as adjustable night platform. But never know may get it build and run it for a bit but then go over to making the coil overs fit. Or might see if I can make up some sort of canter leaves style set up like I have on my saxo
bigT's lcr
Delete. Beat. Repeat...
Feb 27, 2016
1,216
732
Leeds
At the moment it's going to have custom built gaz holds on the rear with damping and rebound adjustability as well as adjustable night platform. But never know may get it build and run it for a bit but then go over to making the coil overs fit. Or might see if I can make up some sort of canter leaves style set up like I have on my saxo View attachment 11707
That looks ace mate!
Andrewwright
Turbo lover
Aug 16, 2016
1,567
224
Peterborough
Finishing touch interior LCR vents. I guess it is the last thing i need to change complete lcr interior.
Verstuurd vanaf mijn SM-G960F met Tapatalk
That's what I'm going to do next year, I've stripped a Leon before but never put the stuff back in, was it an easy swap? Or regret it 5mins in?
Reactions: bigT's lcr
lightup
324
275
dont think so, i bought the engine like this from a engine rebuilder. rods are balanced too but i will weigh the rods and pistons.
Reactions: Manic172
