Pretty much same boat, living in Somerset, 2011 Cupra R with stage 1 and wrapped black roof £430 if I remember correctly, was around £230 before the remap but I hadn’t told them about the wrapped roof.Hi guys, looking to get a MK2 cupra and wondered what sort of money the insurance for a stage 1/2 car is. Been quoted about £250 for a standard car as live in Devon and 40+. Any reccomended company's?
Sent from my Redmi Note 7 using Tapatalk
Did you check the rubber bits that are in the air-box hadn't come off and stuck on the prongs of the engine as that happens every time for me when I take the air-box off I bet that's the problem.On Sunday I purchased my MK2 facelift Cupra and last night I changed the cam follower. Don't think much of the engine cover, mine doesn't seem to want to go back on 100%.
I was running out of daylight, bit from what I could tell I think you may have solved my problem. I'll check later, thanks for the tip.Did you check the rubber bits that are in the air-box hadn't come off and stuck on the prongs of the engine as that happens every time for me when I take the air-box off I bet that's the problem.
I'd considered that so tried for a few days without using it. Can still see through it and I use RainX on the rear window so keeps it clear for the most part.This is just me wanting to know and not being picky but why remove the rear wiper, don't you find it a must?
My Leon is covered in spray within seconds and I rely on it.
