Neil01Cupra
12
13
Made new front centre grill as it was IMPOSSIBLE to find a cupra r grill second hand.
Zardoz
525
214
North West
Looks like the radiator is the cause of my leak, no obvious signs on any of the hoses but a pink/white crust on the front most under tray clips and then again around the frame under the rad housing. I'll get it booked in as I hold my hands up and say that job is beyond me.
On a brighter note I gave the old girl another MrMuscle clean on the cast iron side of the turbo and freed up the actuator arm and she's got more zip back again.
Reactions: Leon20vt4
Yellow fr
Sep 6, 2018
1,547
1,062
Sandbeds West Yorkshire
Just had todo a puncher repair on the offside front wheel and while it was on the ramp my steering rack has got a big leak so it looks like that’s the next thing todo as well as two new tyres rain sport 3 on order
iammooks
1,801
1,198
Fitted the new engine cover insulation last week, and spent half the day under the car today doing the oil change. The sump plug was tighter than a ************. Not the best when I don't exactly have a lot of room to move around. Getting the undertray back on was probably the hardest part. Struggling to get the filter tight though - chain tool doesn't seem to want to grip.
There's a thread in the offside wheel arch where the bolt for the undertray sides goes. It's been missing for a long time (not me) but does anyone know what size nut I'm going to need for it?
iammooks
1,801
1,198
You tighten oil filters by hand then typicly half a turn. Even on hgv they are 35nm
Once I get the proper tool on it, I'll take it out and make sure the threads are really clean before trying again - it feels pretty stiff and I definitely can't get it finger tight. I never usually cross-thread things, but I was getting stressed out by the undertray, so that might explain things.
bruceR
2,566
660
Monifieth, Dundee
If it’s sticking down where the the side cover attaches then it’s just a spring nut thingy.
If it’s a threaded hole then it’ll be the same as the other screws
iammooks
1,801
1,198
That's the one - it's a thread sticking out of the top of the wheel arch.
EDIT: What came up in my google search was the clip you screw the Torx screws into. I'm still researching...
bruceR
2,566
660
Monifieth, Dundee
The VW spring nut is pushed onto the thread sticking down only after you fix the cover over the tread first.
Put the spring nut on the thread concave side first and push it firmly in place.
Reactions: iammooks
iammooks
1,801
1,198
Brilliant - thanks so much for this. I've just put in an order for some - with any luck they'll arrive before I drive to the Netherlands.
I had the side panels removed a few years back after the undertray decided to pick up a ton of weeds driving through a Ford, but when I had it re-installed they obviously didn't have the right parts and of course, they bodged it.
bigT's lcr
Delete. Beat. Repeat...
Feb 27, 2016
1,216
732
Leeds
Fit two new rain sport 3 tyres to the front and did the tracking and also had to wash bird poo off the rear off the car
Few lads at work have them on their fronts you'll have to let me know how you get on with them as they swear by them
Reactions: Yellow fr
