Zardoz
525
214
North West
All set for a service this weekend. And they’ve started putting the air fresheners back in :D Woooo!!!
bigT's lcr
Delete. Beat. Repeat...
Feb 27, 2016
1,216
732
Leeds
what, your daughter fell into the door on Sunday and you taped her in there!?!?
Ay she came outa the woodwork from many moons ago so stuffed her in there so our lass didn't find out. Plenty of water leaking in and im sure some biscuit crumbs made their way in there. She'll be reet... :clown:
Reactions: BadBoy03 and Zardoz
iammooks
1,801
1,198
After taking the best part of two days to replace my tie rods, I noticed this when I was putting everything back together.
I thought at first that the paint on the anti-roll bar was cracking, but I've had a bit of a feel and there definitely seems to be a bit of a kink there.
Is this anything I should be worried about? Thinking back, I had a crash about seven years ago, but it was on the other side, so it's possible it happened then, but in all honesty if it's lasted that long, it'll probably last a while longer too...
iammooks
1,801
1,198
To be honest it does just look like the paint has cracked and gotten worse over time but If you get the tracking done and all is OK then I wouldn’t worry (they are pretty solid bars)
That's a relief - thanks for this. I can't say it feels any different to drive, so I'm hoping it stays that way. While it looks like I can get hold of a replacement pretty easily, it's the fitting that would be the biggest pain - the sort of thing that I'm guessing takes days to do with the car on axle stands or a couple of hours with a lift.
Yellow fr
Sep 6, 2018
1,547
1,062
Sandbeds West Yorkshire
It looks to me as if it’s just the powder coating that cracking and the bar underneath is just going rusty it will be fine as they are think bars so noting to be to Concerned about. I would look to see how your Flexi pipe is and how bad it’s rubbed as it looks as if it’s rubbing on the anti roll bar
iammooks
1,801
1,198
Thanks for this - I'll have a look tomorrow when they've got the wheels off for the alignment. I think there might be a gap, but you're right - I need to find out where that mark has come from.
Yellow fr
Sep 6, 2018
1,547
1,062
They should not need the wheels off for the alignment but you should be able to see if there is any rubbing on the flex pipe
Reactions: iammooks
Zardoz
525
214
North West
Was given loads of Chemical Guys cleaning products and 90% of them have been brilliant (and smell like you want to eat them :D) but the Interior detailer which at first looked good leaves white streaks if rain manages to get in through the window onto it.
Gave the interior a clean up with Halfords own Dash & Trim cleaner, heard it was good and for £4 worth a go. It's loads better and took off all the old residue from the Chemical Guys stuff.
bigT's lcr
Feb 27, 2016
1,216
732
Leeds
I get that with G101 (inerior plastics soap) so i just water it down
