19 for non ventedMin vented disc thickness is 26mm on auto data
I don't run drilled rotors... ever... atleast every single one I have has warped on me expensive or notThrobbing with really gentle braking could be a small warp. You do feel a kind of knock/ throb as the warped part coms round and hits the pad.
J hook shouldn’t in my mind do that. As there are so many j’s that there should be a uniform feel as it spins round if there was a bare section you’d maybe feel a difference.
As said. I run drilled and grooved and never feel them.
Sent from my iPad using Tapatalk Pro
Arrived today. Did you order a set?Have you got the link??
Uuuuulala where did you pick these up? Golf mk4 led set or what?Arrived today. Did you order a set?
Well get those bad boys in and take some photos!Yeah interior light set, posted link a couple of pages back:
Here you go mate https://www.ebay.co.uk/itm/143090452963?ul_noapp=true
Listed as MK4 Golf fittings, but, you know.
Similar sets with only 10 bulbs in UK were listed at over £15!
Not yet. Its on the loooooooong list lolArrived today. Did you order a set?
Have you seen any blue ones??Well they're 40p cheaper now anyway
The rear are crap. Recently had trouble with mine...Replaced the n/s/r caliper after the handbrake mech kept binding This was only about 8 weeks after the o/s/r needed replacing for the same reason.
Yeah, I've seen blue versions of the common bulbs on eBay but you'd have to source them separately. Not seen a full set like that one I ordered.Have you seen any blue ones??
