Is there any difference between:
Activate daylight (DRL) in rear. LED drivers
With this modification when you take DRL lit, the rear lights also illuminate.
1 - Module 09 - Electronic. Code (31347)
2 - Adaptation
3 - Select - Daytime Running Light
4 - Sub - Tagfahrlicht dauerfahlicht aktiviert zusaetzlich standlicht
5 - Change value to On
Scandinavian DRLS
1 - Applications
2 - Scandinavian DRLS
3 - Select On
I want rear DRLs, but my friends tried the bottom option on his 2015 184FR and it's no different to switching over the light switch manually to sidelights, apart from still being able to keep it in the Auto setting. I don't like the fact that the dash, the door card strips, the two red LEDs near the rear view mirror, etc, light up as it now thinks the lights are on. Is there another coding option to just light up the rear lights, so that you can then see when the auto lights switch on the main lights with the two LEDs, etc?
I've just tried this and the app changes that exact setting. So there is no difference between the app or the long coding.
