Is there any difference between:
Activate daylight (DRL) in rear. LED drivers
With this modification when you take DRL lit, the rear lights also illuminate.
1 - Module 09 - Electronic. Code (31347)
2 - Adaptation
3 - Select - Daytime Running Light
4 - Sub - Tagfahrlicht dauerfahlicht aktiviert zusaetzlich standlicht
5 - Change value to On
Scandinavian DRLS
1 - Applications
2 - Scandinavian DRLS
3 - Select On
I want rear DRLs, but my friends tried the bottom option on his 2015 184FR and it's no different to switching over the light switch manually to sidelights, apart from still being able to keep it in the Auto setting. I don't like the fact that the dash, the door card strips, the two red LEDs near the rear view mirror, etc, light up as it now thinks the lights are on. Is there another coding option to just light up the rear lights, so that you can then see when the auto lights switch on the main lights with the two LEDs, etc?
I've just tried this and the app changes that exact setting. So there is no difference between the app or the long coding.
Does anyone know how I can sort this fault (U112400)?
Have you made any changes to the car or the control units on your car.
Also did you add or take out any control units from the list that OBD11 Showed.
You should be able to see this in your history file.
if you go to the upside down triangle at the top of the screen you can filter the output to Gateway Coding.
Looking at the above you appear to have deleted 03 Brakes which I certainly have on my car so add that back in and if that does not work you can do the filter as above.
Anyone had issues with putting the door cards into red permanently and not just on cupra mode? I've done the long coding for red and flash white when indicating. But no red, just blank and white flash on indicate in both cupra and sport mode, not Individaul! Ideally I would just like red with no flash. Any thoughts? Cupra 280 2014/15
Try these settings, gives you red led in all modes
Adaptation
Control unit: 09 Central Electrics
Name: Leuchte16BLK SLB35BLK SL KC9
Values:
Lichtfunktion B 16:
Old value: nicht aktiv
New value: Ambientelicht 3
Mileage: 72787 km
Date: 2019-02-19 07:51
Adaptation
Name: Leuchte17TFL R BLK SRB3TFL R BLK SR KC3
Values:
Lichtfunktion A 17:
Old value: Ambientelicht 3
New value: nicht aktiv
Mileage: 72787 km
Date: 2019-02-19 07:50
Yes it was the brakes, didn't see I had removed them. You are a legend. Thanks mate
Adaptation
Values:
Lichtfunktion B 16:
Mileage: 72787 km
Adaptation
Values:
Lichtfunktion A 17:
Mileage: 72787 km
Will give this a bash tonight cheers buddy
Adaptation
Values:
Lichtfunktion B 16:
Mileage: 72787 km
Adaptation
Values:
Lichtfunktion A 17:
Mileage: 72787 km
Legend for this, just fixed it. Red whe driving and blank when indicating. Which maybe due to old coding which I will sort. But thanks
Reactions: Hawkers
Not checked it out recently but the spanish guys have a great backup site
And of course you can always look at your backup files and or History files if you have changed stuff.
If you cant find what you are looking for let me know which Leuchte you want and I am happy to share mine.
Does anyone know if it’s possible to have “needle sweep” with the digital cockpit?
Also is it possible to have the “carbon” skin with the dc?
No needle sweep working on the Digital Dash as far as I know. Don’t think Carbon on DC is available either.
Possibly something in the works but nothing yet.
Here is an odd one - I have a facelift (MY2017) car, which has the UI accents in Yellow - I have seen that in the latest cars you can configure those to red, which my OCD tells me is what they should be like.
Is this something that can be coded or no chance?
I assume not, but worth asking...
Reactions: gof
