Tell
Surely you can only use this update if you subscribe to Mapcare?
Which is why I was wondering why the other person said great unless he used the MIB2 workaround as per the navigation thread and as I said the Seat link doesn't show the final release so it's not a good link :). You can find some early conversation on that thread of your Mib1 map release, I did a scan on the serial number and found a conversation from way back when.
Anyhow, navigation software rather than firmware conversation should be on there.
Walone
1,629
457
Near Heathrow
It this bit
Nav database 5F0919866K 0045 ECE 2015
The 5F places it as Mib1.
Back up your SD card before you do anything. Mib1 people haven't been successful at map updates if they haven't got Mapcare. Firmware frig allows it but on the other thread a guy was running a business out of it so he never told anybody how to do it themselves.
I wonder if iby104 has changed his car, as if it is a 2017 model then it would be 2+ years newer than MIB1 vehicles.
Reactions: Tell
iby104
76
10
This is my satnav info, is it mib2?
Sent from my SM-G930F using Tapatalk
Reactions: Tell
Tell
Now thats a mib2 not what was higher up :).
That settles that then. You're are still best to use the link I gave you than the Seat one. The VW link. Basically Vag map preparation decided it wasnt going to fit on one SD card so put Europe into five parts, but then managed to do it by popular request and did a re-release. Seat hasn't caught up with that yet. If you wish to keep Europe as all of Europe on the standard system then you pick the new 13gb bundle.
I could diss the mib2 standard against the mib2 high now I have access to both. The problem appears that the road speeds are missing on some types of roads as has been noted so the routing algorithm takes you down silly roads as being the quickest. You don't get those speeds on single track roads where I now live. Pick the red route on both systems and the high puts you on the main road to town, the standard takes you on roads you don't really want to be on if you like your paint work.
Dannnnn
440
200
Hampshire
When I go onto the menu button of my MIB2 I have the spinning menu.
Would the software update change it to the tiles?
Sent from my Pixel 2 XL using Tapatalk
Dannnnn
440
200
Hampshire
In short yes. I updated firmware to give tiles instead of carousel
Did you use the Spanish link to do the update?
There isn't really a decent post in this thread which suggests what to do.
kiddo
ST Cupra
May 30, 2015
1,151
99
Lancashire
Yeah I followed the Spanish thread and it went as expected . The firmware took fine and the unit worked. I needed to use obd11 to change some values to remove error codes which was all documented in the Spanish thread. Have you got access to obd11 or similar?
Dannnnn
440
200
Hampshire
Thanks that's helpful.
Not yet. I was going to get Carista but if it needs some proper coding done I'll get obd11
Feb 28, 2019
How I can update my seat leon iteck 2015 system H41 sw 425 , and i ask if i can edit navi and mirror link and android auto to my system , thanks
Feb 28, 2019
Mar 1, 2019
Hey guys i get this message when i get into the full link. WHAT DO I DO !!!?
PLEASE ANY HELP !!!
kevster184
685
29
I gave up trying to fully update the mib2 high maps as Walone knows after 17 months of trying. The developers menu via SWDL without Mapcare allows you to update voice, eggnog etc but not the Navdb directory which is the map file directory and released POIs........... I tried.
Mib2 High uses the same map upload as Mib1 High so it's been well researched since Mib1 High was released. Going retrofit with your unit is the only way... threw the towel in and followed Walones route of getting you unit turned into a retrofit so you can enjoy all the benefits of a retrofit :).
It seems this is what I am faced with, a no go for my unit to be updated for maps (these threads are over lapping now)
and for who it helps the unit is,
MIB2
Navi Plus (High)
5F0035020
H41
0123
kevster184
685
29
Is there any firmware updates for mine, anybody know please?
MIB2
Navi Plus (High)
5F0035020
H41
0123
Pre 29th May 2015 = Model year 2015
Walone
1,629
457
Near Heathrow
MIB2
Navi Plus (High)
5F0035020
H41
0123
Yes updates are available, I updated mine from 0319 to 1219, had to do it in 4 stages as you can't directly update from 0319 to 1219. Not sure if there are any updates to do between your 0123 and 0319 though. The hardware number (H41) is fixed and can't be changed I think.
kevster184
685
29
How did you find out how many updates your unit needed?
We could do with a list and what for in order
