VW Golf R manual 300 4wd 2014 35000 miles/55000 km vs Seat Leon Cupra R manual 310 2wd 2018 new car.
https://forums.seatcupra.net/index.php?threads/new-cupra-user.447220/
A little
review after a few test occasions yesterday on mixed road types in each car with two different drivers, me as well as my son.
Both cars without engine tuning. Golf R in this case has a CTS intake + CTS elbove inlet pipe, no other pure "performance" changes.
Golf R is as you know 4wd, which makes it much faster from 0-62 mph, 0-100 km/h than the Cupra R due to the grip. Up and running Cupra R is faster. It feels good from the low revs like Golf R, though noticeably better power than the Golf R 300. This applies as long as the road is dry. Cupra LSD (Limited Slip Differential) works very well. It is adjustable from the menu. Now the Golf R is not a 310 hp as the 2018 version is. Probably Cupra R is still faster than a Golf R 310 2018. For Golf R 2019, the power output is decreased to 300 hp again (WLTP certification have impact).
Both cars have DCC (adjustable shock-absorbers). Cupra R is noticeably stiffer in the suspension. The steering is more direct in Cupra R, more agile than in Golf R. The aggressive Camber angle in Cupra R certainly affects the steering control. Cupra R is slightly lighter, which is noticeable of side wise movements.
The noise level in the cabin is quite similar in both cars. The golf R is a lot older but it’s free from rattles. That goes for Cupra R to. Golf R has a permanent open outer exhaust pipes (VCDS tweak of flappers) and an open CTS intake. It would have been quieter than Cupra without intake /flapper mod. Cupra with the engine in "Cupra" mode also offers “pops and bangs” from the exhaust system during gear changes. The latter was highly appreciated by the younger driver!!
Infotainment is equivalent when comparing the same year model of Golf and Leon Cupra (e.g our new Golf Alltrack 2018). The "BeatsAudio" package delivers very good in Cupra R, ThumbUp, so to speak!
A number of details are simpler on Cupra R than Golf R but also on the contrary, better on Cupra R.
We haven’t been able to hardest the brakes because of the humid autumn weather with +3c above freezing point. They are good on both cars. Golf R has 340 mm discs with mono calipers, Cupra R has 370 mm discs (Audi printed on them) with 4-piston Brembo calipers. One can for sure assume that the Cupra brakes can withstand more!
Notification, this Golf R has drilled 2 section front discs from Golf ClubSport S. Don’t make any big difference on the public road from original discs.
Both cars have high level of the interior standard. The multifunction wheel in the Golf has better support for phone + other details that are for the benefit of the Golf.
LED headlights are good at both Leon and Golf in the latest model year. The older Golf R which we relate to in this comparison have xenon.
The feeling of the bodywork, e.g. of door closing sound, are similar. More weight in tailgate on the Golf than the Leon because the “boot sill” is much higher in Leon. You have to lift your bags, not of any importance.
The conclusion is that Golf R-14 still holds what it promised at launch 2013. It is more of a daily driver car. The Cupra R 2018 is a bit more track day oriented but works out as a d-d car to, sportier with the pros and cons of it. I’m very pleased with the Cupra R so far
Since the Cupra has rather few miles on the odo, we haven’t tested the output at full revs…. It has to wait until it has passed about 750 miles.
/Peter
