Deleted member 98136
Andy - Funny turn-out - followed your print -out and I've now ended up with the rear outer red lights going out when the indicator flashes, but NO change in the front DRLs dimming situation.I know what you mean but I'm sure I tried this and it worked.
My advice is just try it,if it only works on one side, code the other. If it doesn't do what you want it to revert to previous settings
Sent from my Moto G (5) Plus using Tapatalk
I think possibly its down to me having previously messed about with the lighting alterating the rear lights to Scandiavan ( on all the time ) increasing light output of front DRLs to max, adding the cornering fog lights, DRLs off when handbrake applied plus numerous other OBD 11 adaptions.
Could even be that the channels are different on my car, as I've read on numerous forums. I did double-check that the adaptions were word for word, so can't believe I've made a mistake there, the rear outer lights supposedly are 23SL HLC10 / 24SL HRA65.
Thanks anyway.
