I think it's impossible for you to eradicate it completely without the electronic diff that the cupras have
Did have a look with a torch and no evidence of damage or any material being removed, there were some contact patches on the insert but I expected that.
Interesting both of you had bent 034 inserts, particularly on a 1.8. What tyres were you both using at the time?
I can only recommend the Powerflex bush (not the insert) in the road version.
Hi,
my previous insert - CTS - sounds to be crashed while i i came back to the level of stock WH after more or less 1,5 years of usage. I need to replace it, but 2 questions.
How can i easily check what kind of version i should order? I have my CTS covered by the washer, so no chance to see from the bottom. Is it the difference due to the gearbox (DSG/manual) that determine version?
Secondly, I think I will go for Powerlex this time - so far no negative feedback, but what would you recommend - insert or full bush and what are major pros and cons? I'm considering yellow one.
do you have yellow full bush or just yellow insert? DSG or manual?Powerflex yellow bush is highly recommended from my side - do on the other hand not get tempted by the black line track version of the bush.
The yellow version eliminates most of the wheel hop and in the odd occurrence when wheel hop happens now it is just a mild stamping. 99,9 % of the time it just spins it wheels now if you are not careful. The general response of the car is improved as well and the insert is otherwise only noticeable for passengers at startup, in reverse and at full throttle where there now is a bit more sound.
A visual inspection is all that's needed no need to disassemble. I reached under car with phone camera to dicipher which mount I had.How to check which version of the mount i have (A or B) without disassembly of my current insert? Is there any model year where change was done?
I know, but have already now CTS insert with washer that covers engine mountA visual inspection is all that's needed no need to disassemble. I reached under car with phone camera to dicipher which mount I had.
