I am confused. Are we still talking about the yellow lower engine mount (large) insert for 34.74 on powerflexes website? Or something additional? There are so many different bits i get a bit lost. Are you saying that the full "ENGINE MOUNT HYBRID BUSH (LARGE)" is serving you better than just the standard insert? Or are you using both perfect_g?
I've been using the purple INSERT for a little while now (with a slight mod to remove idle NVH a little) and it's once again it's starting to hop in the dry, in mild to warm whether, despite better throttle control (perhaps my modification has messed it up...wouldn't be surpised do'h!)
Also, probably a stupid question, but what is the PSI of tyre pressure you guys are all running in combination with these inserts/bushes? I didn't realise for ages when i had my new tyres fitted, the bloke had put them all at 30 PSI all round, rather than the suggested 39 in the front and 36 in back (as says in the fuel cap notation) so recently i've upped it to factory spec and I think it's made it worse...i dunno if higher PSI tyres at the front are causing less grip that before now, i assuming yes as more pressure, less grip, and lower pressure, more grip.
I'm actually being gifted a new, yellow insert to try:
https://www.powerflex.co.uk/road-series/product-details/Lower+Engine+Mount+(Large)+Insert/12384.html (the £34 one) to see if that is better...but if people are suggesting the Hybrid Bush is better then maybe I'll get that instead? Not sure if it looks too complicated to install or i'm just being blind.
Finally, quick check, how much should the bolt for the insert be torqued back up to? I've had it at around 100nm but not sure if that's too much or not enough. 034 said to have it at 130nm which seems way over the top so not sure what the powerflex one should be, it says "factory torque setting for bolt" but i have no idea what that the factory torque setting for the lower dog bone mount insert bolt is/was xD.
