I would suggest disconnect VCDS lead, restart computer, connect VCDS cable to OBD port turn on ignition, connect usb end to computer and wait a while , say 60 secs, then launch VCDS software and go to Options, and Test.
think its the wire doesn't work on a different laptop and tried on a complete different car and still the same
so going ask a mechanic to hook up to car and if it works then going to try a new wire haha
Is your VCDS cable a knock-off counterfeit eBay special? If it is and you've tried to update the VCDS software then your cable will have been bricked and is now only fit for the bin.
Tried doing the one click mirror fold and rain closing windows again today but the option of access control 2 isn't on my vcds for some reason. Could this be different as it's facelift?
Have you entered the security/unlock code?
Try resetting the head unit as that's what was needed to get mine working.Hi all,
I followed the instructions and setting to change some of the setting using VCDS. All the changes were accepted according to the software and I double checked the coding and adaptations after hitting do it, however the changes are not reflected in the vehicle itself. For example, I changed the comfort blinking to 5 blinks and the adaptation shows as such but the car still only blinks 3 times. Also to show the LED when the AC is on auto. VCDS shows it as being activated but the LEDs still do not show.
What could I hav done incorrectly and how do I get the car to "register" the changes?
Thanks for the help in advance.
