Result! How did you fix it?
Things I've done:
Cornering fogs (new bulbs needed)
Needle sweep
Carbon FIS
Lock chirp
Lock mirrors
What else is worth doing?
Walked away locked the car, went back after 10 mins and tad ar like magic. Think I'll leave the carbon effect.
I did needle sweep on mine the other week but it only seems to do it occasionally. Anyone know why?
I've activated Scandinavian DRLs but I'd prefer it if the entire dash wasn't illuminated as if the headlights are on. It'll do for winter though I suppose.
To get this working i had to go to infotainment settings, factory settings, restart vehicle...OBD says that I changed value 3>5 on indicators but they don't do 5 just the 3; also, the alarm chip. I've reset or, at least I think have, the Infotainment system, hold power button until it turns of on it's own?
Any ideas?
BTW. I'm in Ayrshire if anyone wants to have changes made. Reasonable rates!
That's news I like to hear! Did they make any perceptible difference or will you have to be 9/10'th before it makes a difference? Also, how did you know what to change it to if you've not seen the Clubsport S settings...unless you have!
I've changed the XDS setting to its max (Cupra 290), but I've got to say I haven't noticed a difference! I'm guessing you'd have to be pushing it to the limit on a track before its noticeable.
I did the changing of the headlight sensitivity(when in Auto) and changed the ambient lights in the doors to ALL Red and to flash white/red when indicating.
Slightly concerned that my dipped beam(LED) is now permanently on when in Auto. I'll have to keep an eye on this and work backwards if it is.
How did u change all door lights to red regardless of what driving mode you were in?
Im totally new to this so bear with me, i want to make some basic feature modification like needle sweep and mirror fold without hold etc. My car is on lease so will using OBD11 be a problem in anyway if i were to just make basic configuration?
Also i saw this on Amazon: amazon.co.uk/Supper-Bluetooth-Compatible-Android-Support/dp/B014WHK27W/ref=sr_1_8?ie=UTF8&qid=1489453220&sr=8-8&keywords=elm327
Is this the correct one?
Thanks.
