OBDeleven modifications
mattb82
38
Tamworth
A hundred euros, and I'd have to get the soldering iron out! Bugger that, I think I'll stick with the standard ones!
leonisis
Quick enough for me....
Mar 21, 2016
256
66
Bangor NI
Is there an app to change the FIS to carbon fibre? I can't find it.
Put FIS carbon background
With this mod, we change the background FIS Carbon mode.
1 - Module 17 - Code Box instruments- (25327)
2 - Adaptation
3 - Select - Display Image
4 - Select one of the options:
- Option 1 (default)
- Option 2 (Carbon)
Sent from my SM-T520 using Tapatalk
leonisis
Mar 21, 2016
256
66
Bangor NI
Activated carbon background Infotainment
With this mod, change the background screen infotainment to Carbon mode.
1 - Module 5F - Electronic Information 1. Code (20103)
2 - Extended Code (Text mode)
3 - Byte 17 Skinning
4 - Select Skin 2
leonisis
Mar 21, 2016
256
66
Bangor NI
Has anyone coded the auto fold mirrors to unfold via the unlock on the key fob ?
Mine unfold via ignition only. Would like to code them to unfold via unlock on remote. Any help or ideas appreciated
Sent from my Pixel XL using Tapatalk
mattb82
38
Tamworth
Mine fold with one touch on lock and unfold when I unlock the car with the fob. I changed it with an adaptation.
Access control 2
Funk Spiegelanklappung modus:
Old value: by convenience operation via remote control key
New value: by look command via remote control key
leonisis
Mar 21, 2016
256
66
Bangor NI
Access control 2
Thanks for that...Just tried that one....Still no joy.
mattb82
38
Tamworth
Out of interest do your windows go up/down when you lock/unlock the car with a long press? If that's not working as well you may need to reset your windows which may also reset your mirrors.... It's a long shot, but you never know.
leonisis
Mar 21, 2016
256
66
Bangor NI
Yeah they do. All a bit strange....
knappers
16
Is there anybody can do VCDS / ODBeleven mods in Leicester or Coventry (Allesley)?
I have made a few mods using Carista, but all mods aren't available on it, yet.
I don't have an Android device, otherwise I would have gone for ODBeleven myself.
Si.
Jamesb
60
19
Got my odbeleven device yesterday and want to enable retrofit;
- rain light humidity sensor
- Auto lights switch
I am wanting to enable autolights (ch/lh) and auto wipers
Can this be done with OBDeleven?
I read somewhere that modules need vcds but can it be done with through the app?
James
Fraser87
132
Ordered my obd 11. Before it arrives can anyone confirm if there is an option for increasing the time I need to hold down the boot button to release the latch. I have fitted the stronger struts to enable self opening. But have now walked out to my car twice to find the boot lid wide open. Thankfully I guess I live in a descent neighbourhood.
KoNG
528
115
London
jamesb: to be honest with VCDS the are quite behind OBEleven can do more things with decent price and small wireless device. Yes you can do CH/LH with it
leonisis
Mar 21, 2016
256
66
Bangor NI
I don't​ the think you can. I think it's either activated for auto boot opening or not... Is it activating in your pocket maybe ??
Jamesb
60
19
Thanks. I found the coding section which matches the screenshots from vcds users who have shown how to enable the light sensor
Byte 06, bit 00-01, can't see description
Byte 07, bit 07 humidity sensor, already ticked
Is there a database a for long code helper as doesn't seem to be one with OBD eleven?
