Result. Has anyone else done the teardrop wipe coding? I find the wipe is intermittent and does not happen all the time??Thanks got the 5 flashes now
Ok chaps i have a Obdeleven from when i had my Sirocco.
When i try to do some coding i put in 31347 in the security access code in it says invalid code ( also does this with a Vagcom lead ).
My car is a Seat Leon 2009 FR Diesel with 170bhp CR Engine.
Has the security access code changed on this car ?
Ben,
Thanks for the info.
I just went to the security tab then put the 31347 into the window, i thought you had to do that to get the mods working.
Do you only put the 31347 in if it asks for it ? if not just carry on ?
With my sirocco i did not have to put security code in to do most mods.
Is it different with the Seat Leon ?
Have you a foolproof way of getting these mods to work in Obdeleven ?
Cheers.
Gah, just realized i ordered the wrong version. Not the PRO version. Is it possible to uppgrade in the app? Is it the same hardware?
Maybe a stupid question :
- i have reverse camera, no pdc. Can this be activated without hardware mod!
-what is park Pilot?
-traffic sign assist, not activated for me. Can i enable this with obd11?
traffic sign can be enabled if you have front camera. i did this mod, working fine, but every time i start the car, after few minutes error pops up - traffic sing recognition restricted. it only shows up one though so i just ignoring it. From what i read on the other forums its something to do with sat nav and the country you drive in. i have not found solution to this as yet though....
Its the one on your windscreen,behind the mirror. It also operate lane & high beam assist.A stupid question, is the camera on the front you refer to the sensor for the active cruise control and lane departure?
Sent from my Nexus 6P using Tapatalk
http://www.ebay.co.uk/itm/381608950335?_trksid=p2057872.m2749.l2649&ssPageName=STRK:MEBIDX:IT
No error message displayed on mine but the OBDeleven app apparently has a mod to overcome this
Just got these fitted . Great job and no errors on mine either. Thanks for the info.
Just a thought though.......what maniac thought it was a good idea to have the N/S bulb covered by the washer bottle (my FR has the winter pack) I was able to get to it by removing the engine undertray that attaches to the bumper. Bit of a faff to change a bulb but it's worth it for the matching light colour.
Tried to change the display on the infotainment and now have a blank screen that won't function? I've changed it back to skin 1 but nothings happened? Help please
