Guide in progress, watch this space it will keep getting updated throughout the day and tomorrow!
This has been put together from JsyCuPrA (Kev) Researching on the internet and Phillips1795 (Zach) Making the adjustment on JsyCuPrA MK3 Leon FR.
AS ALWAYS DO A AUTO SCAN OF THE CAR FIRST AND SAVE IT SO YOU HAVE THE ORIGINAL CODING IF SOMETHING SHOULD HAPPEN TO GO WRONG.
I HOLD NO RESPONSIBILITY FOR WHAT YOU DO TO YOUR CAR SHOULD SOMETHING GO WRONG.
Passenger Mirror Lowering (Reverse)
1. Select 52 - Door Elect, Pass.
2. Select 07 - Coding
3. Select Long Coding Helper
4. Move to Byte 04
5. Enable Bit 2
6. Enable Bit 3
7. Select 09 - Centr. Elect.
8. Select 16 - Security Access
9. Input Security Code 31347 Click do it and yes if it brings up another box.
10. Select 10 - Adaptation
11. Choose from drop down - (15) Access Control 2-Spiegelabsenkung Bei Rueckwaertsfahrt
12. Set Value to Active - Click DO IT! and Yes to the other boxes that pop up
13. Choose from drop down - (20) Access Control 2-Menuesteuerung Spiegelabsenkung
14. Set Value to Active - Click DO IT! and Yes to the other boxes that pop up
15. IMPORTANT TO REMEMBER - On the mirror adjustment stalk keep it on the L for this to work
Alarm Chirps, Lock & Unlock
1. Select 09 - Centr. Elect.
2. Select 16 - Security Access
3. Input Security Code 31347 Click do it and yes if it brings up another box.
4. Select 10 - Adaptation
5. Choose from drop down - (1)-Ruckmeldungssingale-Akustische Rueckmeldung entriegeln
6. Adjust value to yes
7. Choose from drop down - (2)-Ruckmeldungssingale-Akustische Rueckmeldung verriegeln
8. Adjust value to yes
9. Choose from drop down - (8)-Ruckmeldungssingale-Akustische Rueckmeldung global
10. Adjust value to Active
11. Choose from drop down - (7)-Ruckmeldungssingale-Menuesteuerung Akustische Rueckmeldung
12. Adjust value to Active
13. Choose from drop down - (3)-Ruckmeldungssingale-Dauer der Akustischen Rueckmeldung vom einfachhorn
14. Adjust Value to what you want, we selected Normal
4. Move to Byte 04
5. Enable Bit 2
6. Enable Bit 3
![PassengerWingmirrordip_zps5e1f2bf3.jpg](http://i1090.photobucket.com/albums/i371/Phillips1795/VCDS/PassengerWingmirrordip_zps5e1f2bf3.jpg)
![AccessControl1_zps0083d113.png](http://i1090.photobucket.com/albums/i371/Phillips1795/AccessControl1_zps0083d113.png)
![AlarmChirp1_zps281720c8.png](http://i1090.photobucket.com/albums/i371/Phillips1795/AlarmChirp1_zps281720c8.png)
![AlarmChirp2_zpsb540ff0e.png](http://i1090.photobucket.com/albums/i371/Phillips1795/AlarmChirp2_zpsb540ff0e.png)
![AlarmChirp3_zps92777b3b.png](http://i1090.photobucket.com/albums/i371/Phillips1795/AlarmChirp3_zps92777b3b.png)
![AlarmChirp4_zpsb7d3d80a.png](http://i1090.photobucket.com/albums/i371/Phillips1795/AlarmChirp4_zpsb7d3d80a.png)
![AlarmChirp5_zps04f4c328.png](http://i1090.photobucket.com/albums/i371/Phillips1795/AlarmChirp5_zps04f4c328.png)
