VCDS - How To Guides
john doe
55
question has been asked in another thread, but does anyone know how to change indicators in wing mirror to 'sweep'.
seen on you tube.
chrizsschwarz- moving indicators.
sorry not allowed to post link yet!!!
I've posted a post on that some weeks ago and the answer is that it's a mod, so nothing to do with VCDS on original mirrors.. Sorry mate
ran1990
Hello everybody,
Is it possible to set Start & Stop off on default?
I mean, if I want to activate it I would just press the button.
Thanks.
who.am.i
Leon FR
Jan 23, 2016
392
30
EU
Anyone confirm carbon fis on headunit?or just betwen clusters?how can u reset radio?
vag familia
ysfdncr
176
12
37
New Jersey, USA
vag familia
Carbon look can be done on headunit and between clusters. Head unit coding is at 5F Information Elect. and between clusters coded in Dashboard module. Hold down power button of screen for a minute to reset radio.
Samsung Galaxy Note 5 Cihazimdan Gonderildi
who.am.i
Leon FR
Jan 23, 2016
392
30
EU
Just one more.i coded rear led as drl.but inside the car lights are on too.
any way to turn them,as the xenon turn on?
Additionally coded mirrors folding in one press..but windows closing in case of rain wasnt done.read that only year 2013 and 2014 car is possible.
vag familia
aggie
264
11
I have tried the alarm chirps lock and unlock mod on my Leon 1.4 tsi St 2016 but I am unable to get it to work what I have noticed where you say change to yes it says activate on my 15.7.4 VCRs. Also. There are no labels in control 9 central electrics. I would very much like this facility any advice would be appreciated. Aggie
jacko5
187
35
60
UK
Ok chaps i have a Obdeleven and VCDS and when i put 31367 as the security code it says invalid with both of them.
If the security access code different for my Seat Leon 2009 diesel car with CR engine ?
Cheers.
eoink
21
Ireland
Hi,
Car : 150 FR MY14
I have changed front and rear fogs to LEDs, but I'm now getting an error when I switch them on.
I have looked in VCDS 16.8.4 for the Option to Disable Cold Diagnostics, but can't find it in Central Electrics
https://goo.gl/photos/EzZmTsfNm8FLfB319
Any clues from anyone?
Thanks,
E
EddieP
124
Coatbridge
I have access to a vcds (soon my own OBD11 as well) and have used it before for turning on the cornering fogs, but they only turn on for cornering when the high beams have come on (auto lights) does anyone know how to get them to come on when it is only DRLs?
R4CK5
609
85
Any of you kind chaps on here fancy posting a screen shot of where on the list I might find access control 2 section for the folding mirrors on locking? I have a facelift fr and can't for the life of me find the right ootion. I've followed the guide on here but can't find access 2 or whatever it is.
Cheers guys.
Cupra jonny
35
Is it possible to get front indicators on as drl? I know its done on mk5 golfs indicators obviously still function as normal when in use
g_berserk
Smartass in training
Oct 15, 2014
164
24
Monterrey, Mexico
I found instructions for this in several places, and all of them are wrong.
Took me a couple hours but finally got the phased blinkers to work with rear DRLs and using both rear tail sections.
1 - Module 09 - Electronic Central (Security Code 31347)
2 - Adaptation
3 - Leuchte23SL HLC10
4 - Lichtfunktion F23 -- (Change to Blinken links Dunkelphase)
5 - Dimmwert EF23 -- (Change to 100)
6 - Dimming diection EF23 -- (Change to Maximize)
7 - Lichtfunktion G23 -- (Change to Blinken links Hellphase)
8 - Dimmwert GH23 -- (Change to 0)
9 - Dimming diection GH23 -- (Change to Minimize)
10 - Leuchte24SL HRA65
11 - Lichtfunktion F24 -- (Change to Blinken rechts Dunkelphase)
12 - Dimmwert EF24 -- (Change to 100)
13 - Dimming diection EF24 -- (Change to Maximize)
14 - Lichtfunktion G24 -- (Change to Blinken rechts Hellphase)
15 - Dimmwert GH24 -- (Change to 0)
16 - Dimming diection GH24 -- (Change to Minimize)
17 - Leuchte26NSL LA 72
18 - Lichtfunktion F26 -- (Change to Blinken links Dunkelphase)
19 - Dimmwert EF26 -- (Change to 100)
20 - Dimming diection EF26 -- (Change to Maximize)
21 - Lichtfunktion G26 -- (Change to Blinken links Hellphase)
22 - Dimmwert GH26 -- (Change to 0)
23 - Dimming diection GH26 -- (Change to Minimize)
24 - Leuchte27NSL RC6
25 - Lichtfunktion F27 -- (Change to Blinken rechts Dunkelphase)
26 - Dimmwert EF27 -- (Change to 100)
27 - Dimming diection EF27 -- (Change to Maximize)
28 - Lichtfunktion G27 -- (Change to Blinken rechts Hellphase)
29 - Dimmwert GH27 -- (Change to 0)
30 - Dimming diectionGH27 -- (Change to Minimize)
https://youtu.be/zHRsGKQCZeY
iNowack
39
11
Belgrade
Hey guys,
anyone know what to code in order to Interior lights (door, door switches, central console switches and foot light) be ON even light switch is in OFF position?
It worked by default, I've coded CH/LH on my 2016 FR+tech. pack and after that it works only if my light switch is in position light/ lightON position
NOTE: i do not have auto position.
I've returned all my codes to default state as it was when i received my car but it still not working while light switch is in OFF position
Thanks, in advance,
Ivan
Deleted member 103408
2 - Adaptation
I have put the coding that I applied to my 280 here http://obdeleven.proboards.com/thread/2071/rear-blinkers-coding-video
https://youtu.be/EyUBaX_PBTU
https://youtu.be/d71E24JMcas
https://youtu.be/d0661t1rHOY
g_berserk
Oct 15, 2014
164
24
Monterrey, Mexico
Funny how the coding is so different, almost inverse to what I have, yet, the result is the same.
wonder it could that be due to scandi DRLs, you activated them in long coding or piece by piece in adaptations?
I suspect you are correct, that is why I told people I had done Scandi DRL's and we also know there is coding differences between the facelift cars and my older one.
Re the Scandi DRL's I used the app to do that as it was one of the first things I turned on.
Cheers guys.
Sorry just seen this, on the facelift cars I think the coding is now
Mirrors
On new modules this function can be found here: - Thanks to Admin
1 - Module 09 - Electronic. Code (31347)
2 - Adaptation
3 - Select - Spiegelverstellung
4 - Sub - Funk Spiegelanklappung Modus
5 - Change value "Funk Spiegelanklappung Modus"
