VCDS - How To Guides
leongone
11
VCDS version?
Can anyone pls confirm if VCDS 14.10 will work on a 2016 5F before I upgrade if required.
g_berserk
Smartass in training
Oct 15, 2014
164
24
Monterrey, Mexico
It has most but not all of the files for the long code helper, so you're moving bytes and bits blindly there, which is no problem if you have a guide to follow.
FWIW, I have been using 12.12 with my 2015 Cupra with no issues other than some blind coding, and a friend's 16.8 from time to time, but even that one doesn't have all the files for long coding.
leongone
11
Thanks :coolthumb
biz0n
Poland/Zabrze
Ambient color add/change
Hello all :)
I write shortly how to change/add ambient door colors.
I used VCP but probably it’s also possible via VCDS.
See here (sorry i couldn't add link) ahttps://drive.google.com/file/d/0B769WeMSxQHqekhWbWZtRmxnR1U/view?usp=sharing
Deleted member 103408
thanks for this i presume this is for facelift cars only
Sent from my SM-G920F using Tapatalk
