What did you and your MK2 do today?
hoggy90
Full time sexaholic
Nov 14, 2009
689
Scotland
Hand waxed, hand polished and bumper grills sprayed to match the car
Sent from my D6603 using Tapatalk
nick-fr
128
bristol
Fitted some new bulbs today but not sure if they need adjusting, I made sure they're sitting right so that's all good, any help is much appreciated
Sent from my C6603 using Tapatalk
nick-fr
128
bristol
I've had a 6k hid kit fitted for about a year and noticed the bulbs were a bit tatty so bought some replacement bulbs and the beam looks different now
STU3Y
1,271
Kent
Pull up facing a brick wall nice and close and use the cement lines to see where lights are. That will tell you if they are out of position left to right. Then find centre of your bulb in headlight and locate the cement line DIRECTLY in front of it. Mark this on the wall on both sides unless your memory is good. Then drive back 25 feet. (Around 2 car lengths.) Your headlight beam should line up with the mark you made earlier. If it doesn't adjust accordingly. This is only a rough guide but has served me well over the years and passed every mot.
nick-fr
128
bristol
Thanks for the help all sorted now :cool:
