Deej's mk1 LCR 225
lukehowardd
93
Teflon spray arrived so I coated the inside of the air box and re fitted. Also removed the annoying but of standard feed behind the head light so my larger one fits just nicely!
Stage 2 mk1 LCR amd tuned 291bhp
http://www.seatcupra.net/forums/showthread.php?t=366267
Have you just placed it over the end of where the old intake pipe connects to behind the light!?
rossi46
495
Kent
No I have taken that out as it is a lot smaller and restrictive.
rossi46
495
Kent
Just got the email telling me off lol looks mint mate thanks. Pm me to sort payment and delivery.
rossi46
495
Kent
Old charge pipe bracket against D.K's polished one. Thanks mate.
Now fitted:
Could do with a stainless nut now too lol
rossi46
495
Kent
Ordered these off of an s3. Just have to make up a wiring loom and get them wired into the dimmer switch.
May swap out the middles from my vents so they are red not white though.
D.K
LCR 225
Oct 24, 2007
6,408
se london
Now fitted:
I used black ones on mine.
Get some fine grade wire wool and autosol on that charge pipe and it will bring the shine out, is it a Forge pipe ?
rossi46
495
Kent
Yes it's a forge non resonated one. Got autosol will have to source some fine grade wire wool.
t0m
LCR 225
Apr 29, 2007
8,133
7
Kent
Take the pipe off and do it where it's warm, autosol works better with higher temps. Always go over mine often in the summer for better results.
Liking the vents mate look forward to seeing those installed.
bruceR
2,558
647
Monifieth, Dundee
I done this to mine last year, very easy - check my readers ride for info ;)
rossi46
495
Kent
Cheers dude will do. They should come this week. I also got hold of the loom plugs that the vents plug into from another s3 being broken. Will make the loom a bit neater and easier. Il check your rr out before i do anything!
rossi46
495
Kent
Stereo packed up a while ago so decided it's about time I modernised. All my music now being either on my phone or computer. So went and got this.
Dab, Bluetooth and usb. But most importantly can be red to match the other dash lights!!
rossi46
495
Kent
So got to fitting the dab arial and hands free mic. Took the glovebox out for ease of access to run cables and ran cables in roof lining and a pillar.
Pulled pillar trim off:
Clipped microphone on roof lining and ran cable up inside the roof lining to the passenger a pillar:
Then ran cable along with interior loom and tucked into dash area:
Dropped glovebox out. Only a few torx screws and pulled cable down from dash and ran to centre console behind radio.
Then stuck the dab arial onto the screen and ran the cables for this in exactly the same way and route as the mic cables:
Then rebuilt the dash and cabin area.
rossi46
495
Kent
Before and after radio pictures. Forgive the fascia surround as this has still not arrived. Will post again when it's fully fitted.
rossi46
495
Kent
When the fascia surround arrives il pop the finished pics up. Very happy with its functions and quality. Recommended. Would have loved a double din but did not fancy doing all the work changing the consoles. Very happy medium.
Liam_G87
11
Leighton Buzzard
Just read through your thread mate, very nice car!
What's the sound quality like on the new head unit? I'm thinking of getting the same one. You going to upgrade your speakers?
t0m
LCR 225
Apr 29, 2007
8,133
7
Kent
Nice work mate, head unit must be much better than the old one remember when I changed mine.
