Very sexual. Not sure it will be any more progressive than brembo but definitely have more stopping power. Your still not remapped are you? Think it's about time you got a boost![]()
Sent from my GT-I9505 using Tapatalk
They look awesome behind the wheel! Excellent job![]()
They look very impressive mate!![]()
Thanks chaps. It's been something on my wish list for years and I'm rather chuffed![]()
And so you should be mate as you've done it all yourself that why I always ask you for help first lol
Looks like a tight fit mate! But impressive![]()
That's what I thought. Hope there's not too much flex in the parts once on the move.
Looks great though!![]()
I think I've got some pictures of a 312 front disc on the rear using the standard caliper if you want me to put them up? Shows the bracket used but doesn't give measurements.
Thanks Adam but I'm gong for the Compbrake set up. So many trials and errors with the fronts so I thought I'd be kind to myself![]()
I'll go on record and say that I wish I forked out the £2k for the ECS BBK, rather than sourcing all the parts myself. EVERYTHING is fighting me![]()
So with a need to shim and reposition the bolt holes slightly, I did this:
Three attempts later to shim the caliper rearwards slightly got the perfect fitment. In the process however, it shredded one of the threads on the hub... FFS (think that's the first time I've sworn on print on my RR thread)... In the rain and sleet, I re-helicoiled the thread. Job done. Then I discovered that the outer facing brake pad is fouling the bell by a few mms, so I'm gonna have to sand down the front lip before fitment, but then that's it for the passenger side... On to the drivers side then... Looking good mind
are those the 334mm brackets for the caliper? it can be flipped over to use a 356mm disc!
i cant wait to get mine on now.. you and drka have got them on! better get my butt in gear
You're not quite correct! The bracket is designed for 334mm (using an R32 disc) one direction, 350mm (using a Merc Vento Disc) the other direction. On first fitment, the disc outer edge fouled the inside of the caliper. I had to mill the bolt holes out 3 or 4mm to achieve correct fitment. What a PITA that was!
ah yes your right.. The chap I bought the bracket off also said that lol but he had modded the ecs ones too which fit the 356mm but there was no way getting the specs for the disk.
since he had designed thr bracket hes is kind enough to help me with thr rear upgrade too.. 4 pots and the parking caliper
Ah I see what you mean! What break pad did you choose to go with them? On my old ATE setup the brake pad was super aggressive and would grind at lower speeds [probably due to the grooves as well]. The down side also was that you didnt get the majority of the performance until you got some heat into them which wasnt great for town journeys. I dont think you will have that issue anyway.Maz, progressive in terms of pedal travel as I've now gone from 4-pot to 6-pot. This fortunately or unfortunately (depends how you see it) creates slightly longer (progressive) pedal travel; however slightly less than the 17z variant. You can adjust the handbrake to assist along with using specific brake fluid (now using Brembo 6000). It's something I'll get used to and become confident with over time I'm sure. Stopping power will be greater for sure.
Map wise, my exhaust is literally falling apart so a TB system is likely to be one of my next big purchases and that'll need to be mapped in, so looks like my hand will be twisted to a mild stage 2, given the all mods, car's age and mileage. Revo linear will be my choice.
