Washed it and gave it a rub of quick detailer, gleaming! Also noticed the rear bumped jacking point cover was missing, but found it by the side of the road again, phew!
finally got front h@r springs on and 2 new drop links fitted brakes also bled although still not 100% maybey bed them in for a couple of weeks then bleed them again as i have just put new disks and pads all round .New front tyres on tomorrow rainsport 3,s and wheel alignment. going on ebay for some new mats now so i can throw out the rubber ones lol.
What shrouds did you use?
I'm thinking of doing the same with mine.. I'll probably do the high-beams also, but I do not know if I can use them as high-beam since it is probably some differences in high- and low-beam?
Where did you bought them? At their webpage the cost €90 (about £75). Can't find any dealers for this in Norway either...
The shrouds are Mini Gatling Gun, I think the only ones that fit in our small headlamps.
Quad setup can be done, but it's more complicated since our high-beam socket is H1 and requires modification to fit the Mini H1 projector (it fits plug&play only in H4&H7 sockets).
I got mine from a local shop, you can also find them on ebay, direct from China.
Will put one on later.
Easy to do, pull out the grill, prise off the chrome bit, flat it down, primer, paint, lacquer, leave it to dry, reassemble, reattach to the bumper.
Today I did the full n249 bypass, why I dunno car feels exactly the same lol but I was bored.......
Sent from my C6603 using Tapatalk
