help please
Hi buddy in pic 20 where you take the plate off and remove all the pipes..what is that called?? I have a seat leon 1.8t 20v with the n249 bypass but the plate you have taken off is missing and the two connectors are not plugged in there just hagging there!! when I hit 3.5/4 rpm the car holds back and stutters, when this happens I can hear a valve breaking down surcharge sound could this be the n75 valve breaking down?? iv only had the car a few weeks and it was running fine but since the car started playing up it feels like its over boosting and running rich, iv replaced the MAF sensor, spark plugs, coil packs and its running better but still stuttering and holding back at 3.5/4 rpm had it on computer yesterday here is the outcome.
fault code 17840 secondary air inlet valve n112 open circuit
fault code 17695 recirc vavle for turbo n249 short circ. open circ. voltage supply to low
fault code 17968 (p1560) maximum engine speed exceeded
sporadic fault
fault code 17608 (p1200) recirculating valve for turbo charger n249 mechanical malfunction.
I take it the n75 cant cope with the boost?? am i right i need a new n75 valve?? or is it becasue of the two connectors that or not connected??
I have a seat leon 1.8t 20v 2002
many thanks
