I'm in the middle of fitting my solid top mounts, I had to grind off 0.9mm on the turret to allow room for the lip on the mount.
When I did this and go place the bottom half of the mount up into the turret it just slightly not right.
This is where it's going to get confusing, below the photo shows the offside turret. This is untouched at the moment and you see that the lip is larger towards the front of the car
The next photo shows the near side that I have been working on and again the lip towards the front of the car is much larger
(Sorry missed out the 't')
The lip on the face of the top mount now fits perfect if I place it upside down and fit to the turret hole it fits perfect and measurement with the vernier shows I'm +50 microns max to the top mount BUT when I place the top mount into the turret it just slightly doesn't sit right!! As you can see below
I'm thinking that the shoulder of the top mount is following the turret and because the hole is offset the lip on the top face isn't lining up. Now I'm not sure to keep enlarging the hole or to start working on the side that as the larger lip.
These mounts were for a Mk3 Golf, the
Ibiza uses the same top mounts so these were the closest I could find lol. Here's a photo of them taken apart so you can see
