Mk1 banana
334
(Not so) Sunny Hastings
Seems ok as it is now. I will monitor. I can imagine tuners arent convinced by them as they tune, the split R may also need adjusting turning into a ball acher..?:shrug:
Defo be keeping hold of the 007 for now
They are probe to leakage, I wouldn't change mine haha. They weren't impressed when I went for stage one and let them know, still done it and they didn't get any jip with it :)
When I was running standard, I wound it out (anti clock) till it stopped, back in 19 clicks, then every time I hit limp mode, wound it out a click, turn engine off, back on, try again...
It'll work In the end:)
Seems I'm not the only one who needed coil packs within minutes of a remap :)
Shocks, (lowering) springs, new top mounts with bearings all together, ready for installation next week, if 'R' shocks fit the Cupra... Hmmm, lol
Sorry about the long post guys :/
joshy514
Fleet Air Arm by ability.
Mar 2, 2012
1,836
Gloucester
www.seatcupra.net
Just found a decent bit of wheel knock on the front, full lock right, pull the bit of wheel poking out and it properly moves...... MOT tomorrow aswell :( never ending at the moment!! Anyone any ideas? I'm thinking maybe steering rack or wheel bearing!
joshy514
Mar 2, 2012
1,836
Gloucester
www.seatcupra.net
Might be the lower arm bushes
They're polybushed about 10000 ago so I doubt it's these....
If the wheel moves then its probably the wheel bearings, doubt its the steering rack or a drive shaft
I'll have a look later, or see what the MOT flags up.... it's going into a place with a policy thats £50 for the MOT with a free re-test within 14 days so anything wrong I can get one, just all money thats the thing....
Dlp1984
226
Sidcup
I tend to find (a personal opinion) any place that offers a free re test tend to be more picky. Example, I had a mk1 mr2 and it had in the past a bit of welding done, it wasn't the best but was strong. The mot garage I took it to with 2 free retests twice failed it on the weld even though my dad and I welded it up so much it will probably outlast the car, so took it to another garage that offered no free retest and they said it was fine, but was more worried about the hole in the sill the other side by the drivers seat belt :rolleyes: but like I say just my personal opinion of course.
Anyway I fitted some stickers to my car cos I'm a sticker wh0re :D
csd_19
2,279
28
Angus / Edinburgh
The wheel bearings on the Leon are designed in a way that even when they're worn and whining like a biatch you don't get wheel movement, just noise.
I'd check your balljoint and track rod ends mate :)
L60N R T
Im delighted to say that today. ..well yesterday but thats not the point... i finally found bought and fitted recaro front and rear seats to my Leon Cupra R.
My old ones were cleaner but they wernt recaros. Sit a bit higher in the recaros than the normal LCR seats but worth it .
nd-photo.nl
3,668
22
The Netherlands
www.nd-photo.nl
Sep 4, 2012
719
Rainham essex
Cleaned my throttle body. Think I need to remove the inlet manifold and intercooler and clean them aswell.
Before
After
