Something a little Different....
joshy514
Fleet Air Arm by ability.
Mar 2, 2012
1,836
Gloucester
www.seatcupra.net
He had rubbish trade in on his 2 year old Corsa, got like £5000 for it.... He's spent over £40000 on Corsa's once this one's paid haha! He's only 24 too! It's full leather I think, but no nav, It was a display model.... curbed 2 wheels the week he got it! Then a gardner using a strimmer put his rear window through lol. It is a nice car, but only just dicked me coming off a roundabout, both in 3rd and this was before mine was mapped, and it's a tdi! Is this you by the way? https://www.youtube.com/watch?v=Lm7AcBmMyCM
Dale!
Robbie C's Personal Techy
Jan 11, 2011
193
Swindon
He paid way too much... We got one at local dealer as pre reg for 18k in chilli orange... Doesn't sound like he had alot of luck lol... You have the dirty diesel toque :) yer that's my Corsa B with old exhaust when it was first built in 2010....
Dale!
Jan 11, 2011
193
Swindon
Little update I wrote a "How to fit M tech short shifter" when I fitted one to a friends car so I thought it was about time I fitted mine...
How to here:
http://www.vxronline.co.uk/forum/showthread.php?209775-How-to-fit-M-Tec-M32-Short-Shift
Here a few different pictures..
The short shift
M Tech vs Standard
All fitted
Really like it now, alot shorter and nicer to drive... Doesnt feel as "loose" which is always good. Great cheapish mod!
Dale!
Jan 11, 2011
193
Swindon
Alan came down today for an oil change and MOT, he changed his defusser so I had his old standard fin part...
Part way through
All fitted
Thats all for now :)
Dale!
Jan 11, 2011
193
Swindon
Nothing really to update apart from my friend took few shots with his SLR with the nice weather so I thought I would share a couple...
Then i took a couple, very dusty in the barn :(
Feb 14, 2012
684
Slough
They are so nice, the only thing that i personally dislike is the colour of the calipers. I just don't think it fits into the theme of the car. Main thing is you're happy with it though. Any plans for the engine?
bmouthboyo
haha couldnt believe my eyes at first, didnt expect to see that here
Dale!
Jan 11, 2011
193
Swindon
Agree about brakes, early ones had the red brakes to match the R but later ones have blue brakes... Weird! As for engine plan is to fit de cat, con rods and pistons but that's it more of a safety feature... Don't want to ruin it...
Haha nothing wrong with Vauxhall mixture of all 3 in here too
Dale!
Jan 11, 2011
193
Swindon
2013 rebuild has started :)
Been to pick up my engine bits from SteveBoySlim today...
Work thats been done:
Block decked
Over bored to 87mm
Front pulley, crank, flywheel and clutch cover balanced
New omega pistons
Arrow rods
bearings etc...
Head is to follow shortly spec will be listed then...
Few shots of the block
TTV front pulley
New bearing and seals
Omega pistons
Some lubes for building
Had Nortech make me some inserts as i'm on type 1 engines mounts and there isn't any solid mounts on the market :(
Empty bay..
More to follow soon
Dale!
Jan 11, 2011
193
Swindon
Glad to see 2013 rebuild under way :)
Cheer yer getting back into it :)
Little update
First job was to check the piston ring end gaps
Built up the arrow rods and omega pistons :) then fitted
All built up and fitted in place
I have changed to multi ribbed belt setup this year, bought this cheap...
Change of tyres to Toyo R888, may only use these up and go for AD08's
All built up as far as I can go until head here, shafts in etc
The engine mounts seem alot better :)
Dale!
Jan 11, 2011
193
Swindon
Little update, A friend pointed out I did an novice mistake and fitted pistons 180deg out... cut outs are larger for inlet... easy to see when pointed out but werid part is the writing is now upside down... Anyway sump off and swapped them around... Job done...
Dale!
Jan 11, 2011
193
Swindon
Glad someone spotted it, i bet. Lol
Soon be fired up :)
Yer I'm glad risk you take building it yourself tbh... Shocked I missed it TBH was to busy checking end gaps making sure it was all right and completely missed this :( All sorted now, hopefully running in next 2 weeks
Dale!
Jan 11, 2011
193
Swindon
Got my manifold, tial external gate and external pipe back from Zircotec today, went for performance White... Really happy with the finish..
Got my order from Opie oils through too
Gearbox oil
Running in oil x2
General oil x 3
