oooo did you give up on your exhaust?
Downpipe with Sports Cat will be fitted later this month with RS4 valve
Cat-Back exhaust will be done whenever Scorpion decide to do it
Sent from my GT-I9100 using Tapatalk 2
Just an update: coil pack fitted and that error codes gone. The CANBUS error code is still there and causing issues. When driving it you can only get a few hundred metres until all the engine management lights etc flash up again. The dealer is refusing to investigate further until ALL electrical mods have been removed. So all LEDs, sub woofer, stereo etc, good job my parents are travelling tomorrow so I can get my stereo brought over. Gutted to say the least. No idea when I'll get it back now
Bad news
Your car is AMAZING, Can I have it pleaseeeeeeee
Mate that does look spot on
Sent from my LG-P920 using Tapatalk 2
Yeah they look Wikid. I also have hid fitted 8000k with led side lights.
It is yeah, absolutely gutted, makes you feel like just getting rid of the car and changing brand. I'm going home tomorrow but the car won't be, it'll be left here until they fix it. Got to pay £55 for the original stereo to be fitted because I don't fancy messing with it, then the work will commence. To make things worse I won't have a courtesy car, and can't be insured on my parents policies fun fun fun.
Seems like they are being extremely unhelpful with you mate.
If they think the radio is part of the problem it would only take them 10 mins to disconnect it.
You'd of thought that would be part of their fault elimination anyway.
Can't see how that's being the management light on etc.
I've once seen something similar on a Fiat and it was one coil pack spiking the system.
Have they only replaced one coil pack? It would have been a good idea to substitute the other coils first before digging into a fault which occurred at the same time as one coil went off.
They've all done the same mileage and same age.
Liverpool washing their hands of a problem again, that isn't like them...
I don't understand why that would bring on the CEL again though, the problem must be related to the misfire, because you never had the CEL on before the misfire, right? Which means the canbus error has been triggered by the engine fault. So why they are asking you to remove you stuff is beyond me.
Where they any more specific about the error code? I can't figure out what it is.
Hope you sort it.
Bet its another coil at fault.
There were no issues at all with any errors what so ever before the misfire. The misfire occurred then all the dash lights came up. Because the error is canbus they want everything that may have been added to the can bus circuit removed, so all canbus wiring is as it was when it came out of the factory. They can't be more specific because they're bloody useless!!
I've taken your advice and tomorrow I will shift it to Warrington one way or another...
Yayy, I'm sure they will get it sorted I'm going with Kev and saying another coil may be the issue, or a sparkplug
Hi newbie question coming up....whats the benefit of an rs4 valve?
On stage 2+ on revo mapping the standard valve cannot sustain the requested fuel pressure. WIth the RS4 valve the requested pressure can be maintained and surpassed
