GUIDE: The Mk2 Leon VAG-COM Guide
mrbubba
463
Oh right, so after enabling it via coding I then have to go into the Adaptive Section??
Yeah there are some boxes that you need to put some figures in (can't remember exactly as it doesn't work at all on mine)
There was someone who posted it in the tips thread
Sent from my Desire HD using Tapatalk 2
rebel69
Dark Matter Power
Dec 10, 2009
83
Kent
On my stylance I have to leave the light switch on "ON" for the coming home / leaving home to work.
On DanGBs car I think work if they are on or off but mine wont work if theyre off.
Try setting time to 10 seconds through MFD and then leave lights on and test.
Hope this helps
Reb
boditza
67
Craiova, Romania
Has anyone activated indirect tyre presure monitoring system (TPMS)? I tryed it but i don't have a SET button and the light just blinks in the dash.. My ABS controller is MK70
Nath.
The Gentlemans Express
Jan 1, 2006
8,620
16
EASTLEIGH, HAMPSHIRE
My facelift MK2 has the heated mirrors but I found that they didn't get very warm at all.
A quick look on VCDS in cent elec, adaptation showed the heated mirror and rear screen time delay setting. It says it can be set from 15 secs to 600 secs (ten mins), mine was set to 15 secs so that's why they didn't get very warm then. So I attempted to crank it up to 600 and it wouldn't have it. 255 was the max it would allow (I guess that's a hexadecimal thing)? But why won't it let me enter 600 when the little info bubble says 15 to 600 secs?
255 seconds is only 4.5 mins so they won't dry out very well in the rain.
Anyone.
AndrewJB
Aug 16, 2007
11,209
485
Maranello
Doesnt that mean it will take 15 seconds after the button being pressed for them to start to warm?
i dont think thats the total length in time they stay on
Nath.
Jan 1, 2006
8,620
16
:shrug: Well I set it to 255 and sat with the engine running for a few mins and they did get hot. They didn't get hot at all before.
I dunno, I need to have a play and time them.
Nath.
Jan 1, 2006
8,620
16
Yes my pre FL MK2 used to too and my Exeo was the same. This FL MK2 up until today just made them luke warm and after a minute or two they were cold again. The dew didn't even dry off of them this morning.
sfmk2.
878
Anyone.
A bit of a late reply, I know, but is it not a multiples thing? I was looking through mine the other night (I recall it being set to 600), and remember seeing a lot of options to set multiples, so like 10 x 60 seconds etc...
I'll have another look for you in a minute, I'll go and hook her up.
AdamRoutley
Use The Force!!
Feb 22, 2007
1,827
Walsall
www.myspace.com
right.
Just had my cable and switched on a few things.
Did a scan and the only fault was this;
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0203
Revision: 00020000 Serial number: 00000000000000
Coding: 198000005283CC7F0006050560085F86107C80
Shop #: WSC 61021 210 01881
VCID: 830EB866C20EB9B
Subsystem 5 - Part No: 1P0 951 171
Component: Innenraumueberw.010 4971
Coding: 00000000
Shop #: WSC 61021
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Component: NGS n.mounted
1 Fault Found
01135 - Interior Monitoring Sensors
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 4
Fault Frequency: 43
Reset counter: 68
Time Indication: 0
Any ideas?
AdamRoutley
Use The Force!!
Feb 22, 2007
1,827
Walsall
www.myspace.com
just to confirm,
Leaving home lights work without the lights being switched to on!
I dont have a coming/leaving home lights button either!
The lights switch off when you open a door!
Arnie-Wilson
Leon 1.9Tdi Stylance
Jan 29, 2011
163
Portadown, NI
Got most of the things i wanted to work activated, thanks for the info Dan!
One thing i couldn't get working was 'Leaving home lights' Wasn't sure what to activate. Anyone shine a light on this for me?
Info: 2008 model Stylance, Dont have auto lights
boditza
67
Craiova, Romania
Open the door, and pull the light levertowards you. It should stay on for a number of seconds :)
