That would have been Mr OCD's saga....BOUNCY !!! He's now trying LCR set-up,maybe ??
Look forward to measurements to gauge against mine.
Hi again mate,
Just done some measurements for you, with regards to measuring, I was not sure if you meant right to the very top of the wheel arches or just along the outer arch where the paint work is but I have done 2 sets of measurements for you so here you go:
FRONT, to the point on the arch where the paint work is - 67cm (the driver's side measures at 66cm, most likely because the new springs still need to settle)
REAR, to the point on the arch where the paint work is - 66cm both sides
FRONT, to the very top of the inner wheel arch - 72cm (again, drivers side measures at 71cm at the moment)
REAR, to the very top of the wheel arch - 78cm both sides
I hope this is some use to you mate
Liam
