Triple R Splitter fitted now
WOW! That, sir, looks very very smart indeed!!
Guest, 🎅🎄Looking for a stocking filler idea? Why not treat yourself or a loved one to our high quality CUPRA or SEAT valve caps. Order now from the merchandise store
Found it
Step 1: Connect up to VCDS/VAGCOM in the usual manner, then select Instruments under the Select Control Module menu.
Step 2: Select the Coding sub-menu
Step 3: Select Long Coding Helper
Step 4: Select Byte 0 Bit 4.7 drop-down menu then select 10 Country: Rest of World (RoW)
Step 5: Exit Long coding helper then hit "Do it"
That's all you have to do on VCDS/VAGCOM but now you will have to change your MFD Settings, Units menu to the correct UK format from US format (imperial to metric).
Step 6: Un-tick the Alt.speed dis to activate the "Alternative Speed Display"
Step 7: Final stage - Change your units for Consumption to MPG and Temp to ˚C.
It was mad aware to myself that i should maybe look at getting the part behind my number plate done in black gloss (same as rims,roof,mirrors and spoiler as of thursday). Ran up a quick picture of this on paint and just wanted peoples thoughts ? I really like makes the rear stand out a lot more and appear more fresh!
Before
By c17off at 2012-08-14
After
By c17off at 2012-08-14]
Opinions please thanks
I've seen this on a few now and it looks really good IMHO. I've been thinking of doing it for ages too just don't trust myself not to screw it up!It was mad aware to myself that i should maybe look at getting the part behind my number plate done in black gloss (same as rims,roof,mirrors and spoiler as of thursday). Ran up a quick picture of this on paint and just wanted peoples thoughts ? I really like makes the rear stand out a lot more and appear more fresh!
Before
After
I've seen this on a few now and it looks really good IMHO. I've been thinking of doing it for ages too just don't trust myself not to screw it up!![]()
i found this ... obviously an imitation of the twintercooler but, would it work for a fraction of the cost?
http://www.ebay.co.uk/itm/VW-GOLF-M...1327797558374349009&pid=100015&prg=1006&rk=1&
i know alot of people who use turborevs on their PD and 20vt.
not sure if the golf kit would fit, i asked forge about an Octavia kit to fit to my old FR they said hose length was a problem
Staging is awesome. Especially at night!! Zooooom
