oh ok fair enough good to see the progress moveing again.
been doing a bit of welding myself at work recently making tools and i just cannot seem to get the sort of high quality weld i used to its so annoying but i think its because im using a gasless mig welder rather than just a mig or arc welder.
seeing nice welds in threads like this frustrates me more lol.
Cheers mate, it feels good to be moving forward again. And yeh your probably right about the gasless MIG wire.... i really struggled myself with it. Do yourself a favour and invest in a bottle - i bought mine it was £100, cos i went for pure argon (for the stainless manifold a bit more expensive than a co2 mix) and when it's empty you take it back and they exchange it for a full one for £40. When your finished your project you take the bottle back and get £60 back.
----- Another Smallish Update ------
I started today working on the area in the footwell where the upright will mount for running up behind the dash.
Started cleaning off all the seam sealer and moving the wiring loom out of the way to make way for the strengthening plates, i ordered up 6 - 3mm thick plates for roll cage mounts.
I then got the cardboard out and made up some templates - then made the first piece -
And after much grinding and cutting of the next pieces -
Glory shot all tacked together -
I wanted to put the upright in next but the windscreen was getting in the way so i started to cut the sealant out with a new tool i bought off ebay. This tool is a couple of t bar handles and a pokey knife to stick the wire through the seal.
It took me a while to get the hang of the tool, it was a total pain to do. Also i couldn't cut through the sealant at the base of the windscreen there's a plastic bit at the base of the windscreen that i couldn't work around. In the end i just rived the screen back and cut it free with a stanley.
Still gonna have to cut all the broken glass away but i've finished for the day now.
Windscreen Out -
Hopefully get a little bit more done tomoro,
Cheers For now.
